i need a shop that installs turbo kit in los angeles. do you know any?
Old Apr 8, 2004 | 07:02 PM
blkeg2's Avatar
Default i need a shop that installs turbo kit in los angeles. do you know any?
Old Apr 8, 2004 | 09:08 PM
Ek00fbp's Avatar
Default Re: i need a shop that installs turbo kit in los angeles. do you know any? (blksol62103)
what turbo kit and what car?
Old Apr 9, 2004 | 07:58 AM
blkeg2's Avatar
Default Re: i need a shop that installs turbo kit in los angeles. do you know any? (Ek00fbp)
93 honda del sol si and greddy kit 15g. i need a shop that can install the kit, guages, boost controller, turbo timer, and v-afc.
Old Apr 9, 2004 | 08:36 AM
f22sohc's Avatar
Try Street Image in Baldwin Park. Just one of the many shops in the LA area.
Old Apr 9, 2004 | 09:08 AM
Rod.'s Avatar
Default Re: i need a shop that installs turbo kit in los angeles. do you know any? (f22sohc)
save your money and do it yourself. It will be fun and experience.
Old Apr 9, 2004 | 09:44 AM
calib17a's Avatar
It's not that hard to install. The kit should make it pretty easy. Boost controller's simple also, if manual, just a couple of vacum hoses, if electronic, hose connections plus power,ground and ignition can be tapped at the steering column, same with the turbo timer. What guages do you have besides boost (manual or electronic)?
infamouskillas
Apr 9, 2008 09:35 PM
Fallen86
May 13, 2005 11:15 PM
ptsiu
Oct 15, 2003 07:18 PM
armharm
Dec 12, 2002 06:10 PM
GumballNA
Sep 11, 2002 08:40 PM
