GLASS Sunroof for a 4G Lude?!
Old Apr 8, 2004 | 02:37 PM
RHD_BB4T's Avatar
Default GLASS Sunroof for a 4G Lude?!
I've always hated the metal sunroof panel, and I really hate that Honda never made it an option on the 4th Gen Preludes... well, here's right back atcha Honda! (Did this in about 30 minutes, BTW!)
Enjoy!
Old Apr 8, 2004 | 02:38 PM
4bidden's Avatar
So you always have sun shining on your head no matter what since there is no panel to block it off, right?
Old Apr 8, 2004 | 02:45 PM
@ries's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (RHD_BB4T)
Looks great! I've had to replace my stock one due to some rust issues. Care to share what car/model the glass came from?
Old Apr 8, 2004 | 02:48 PM
H_doubledeuce_A1's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (emoBB1)
Hmmm I'd always wanted a glass sunroof for my 4th gen. Only prob that I can see is that there's no cover inside.
Old Apr 8, 2004 | 02:56 PM
RHD_BB4T's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (H_doubledeuce_A1)
Yeah, I'll share... Hehehe
The glass is off of a 5th Gen Lude. We had one laying around our shop. Was actually pretty simple. The mounting tabs and studs had to be modified a bit and the bump-stop tabs removed. Also, if you don't shim the whole assembly before installation, the glass will actually protrude up and out of the sunroof hole when the sunroof is closed. Other than that, it went together pretty easily. Sure there's no sliding panel, and the sun shines in. But that's the point of a glass roof. If that's not what you want, then keep the stock metal panel.
Modified by RHD_BB4T at 12:08 PM 4/14/2004
Old Apr 8, 2004 | 02:59 PM
bdb's Avatar
bdb
Are you saying that the openings are the same size between the 4th gen and 5th gen? Cause if they are, I'd like to buy your metal sunroof!
Old Apr 8, 2004 | 03:12 PM
RHD_BB4T's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (bdb)
bdb:
The 4G and 5G sunroof openings are the same size. However, the way they mount to get sliders/rails is SLIGHTLY different. Not too hard to modify, actually. Also, like I said before, the 5G glass sat a bit higher than the roof-line after normal installation. Therefore, I had to shim the sunroof assembly downward slightly. I would imagine by mounting a 4G metal panel into a 5G assembly, you would have the opposite effect, and would have to shim the actual metal insert itself...
Hope that made some kind of sense!
Old Apr 8, 2004 | 03:27 PM
AndyD's Avatar
DAMN!!! That is AWESOME!! You are kije Jessie James on Monster Garage.
Have you tested to see if it leaks??
Old Apr 8, 2004 | 03:41 PM
RHD_BB4T's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (AndyD)
AndyD:
Thanks! I have not had a chance to road test it yet other than pouring a little water over it... My car is kind of in a trasition at the moment:
https://honda-tech.com/zerothread?id=825734
But, I can say that the seal on the glass panel seals just as tight as the stock metal panel seal. And, as long as your sunroof drains are working, I don't think there should be any problems with leakage!
Old Apr 8, 2004 | 04:45 PM
ludeR917's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHD_BB4T &raquo;</TD></TR><TR><TD CLASS="quote">I've always hated the metal sunroof panel, and I really hate that Honda never made it an option on the 4th Gen Preludes... well, here's right back atcha Honda! (Did this in about 30 minutes, BTW!)
are you saying that there is no glass sunroof for the 4th gen? im asking cus i got a glass sunroof.
Old Apr 8, 2004 | 04:53 PM
satan_srv's Avatar
so bascially there is no more metal things on the back holding the rubber seal on? I can't imagine it will stay on there for a long period of time...
Old Apr 8, 2004 | 07:42 PM
RHD_BB4T's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (satan_srv)
The rubber moulding is a part of the glass panel... trust me, it's not going anywhere!
LudeR917:
OEM or AFTERMARKET? I was under the impression that the US 4G's didn't have that option? There's no part numbers for 4G GLASS parts that I'm aware of? Could you post a pic inside and out, please?
I've never SEEN a 4G in person with a glass roof (That doesn't mean that they don't EXIST, I guess. If they do, it's a rare thing to see one - at least around HERE.) So for me, it's just as easy to swap one out like I did rather than going around looking for one, that's all...
Old Apr 8, 2004 | 07:55 PM
JG Luder's Avatar
Glass sunroof's were NOT an option on the 4th gen.
Anyone that has one on their car has a custom fit piece. Like RHD's.
BTW, best of luck with the whole RHD conversion. It's a bitch.
Old Apr 9, 2004 | 01:27 AM
JohnnyTequila's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (Lone Luder)
Quality
im sure a lot of 4G people will enjoy this.
i think it looks a lot better too
Old Apr 9, 2004 | 02:28 AM
kstokes's Avatar
Oohhhhh...Nice!
I've often wished I had a glass sunroof.. *starts pondering*...
Old Apr 9, 2004 | 02:52 AM
95PreludeSi's Avatar
You don't happen to remember the weights of the two pieces do you?
-Mike-
Old Apr 9, 2004 | 06:14 AM
AndyD's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (95PreludeSi)
Does anyone know if the 5th Gen has a sliding sunshade??
Old Apr 9, 2004 | 10:09 AM
sfjdmlud3's Avatar
Hey just wondering. All you need is the 5th gen glass and some modification? HOww bout the 5th gen motor and etc? I dont know anythign abotu sunroofs but i sure want that glass roof on my lude.
Old Apr 9, 2004 | 11:10 AM
bdb's Avatar
bdb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if the 5th Gen has a sliding sunshade??</TD></TR></TABLE>
Yes the 5th gen Prelude DOES have a sliding sunshade.
Anyone want to buy my complete 5th gen sunroof?
Old Apr 9, 2004 | 01:25 PM
mike640's Avatar
How much do you want for your moonroof?
Old Apr 9, 2004 | 01:49 PM
RHD_BB4T's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (mike640)
Hehehe. Thanks for the offer, but I don't think that I'll be selling the metal panel just yet...
95PreludeSi:
I'm not sure what the exact wieghts were... I can wiegh the metal one that I took out and let you know what I come up with, and I CAN say that the glass was a bit heavier. But not by too much, though.
I'll be looking at the broken 5G sunroof that we have at the shop to see if there's any way at all to retro-fit the sliding sun-shade the next time I get a chance to play around with it, so stay tuned! (I'm doubting it would transfer over, as it's a part of the 5G sunroof rail system and not the glass itself... we'll see)
Old Apr 9, 2004 | 10:24 PM
92LudeSI's Avatar
Might sound dumb but ive been trying to figure out how the hell to get to the sunroof mouting bolts and such. Do you have to take the interior roof off or what? I didnt feel like tearing it all apart and finging out it wasnt necessary thanks.
Old Apr 10, 2004 | 07:44 AM
wstef's Avatar
Looks great!!! I will do the same in my lude!!! This will resolve the problem with my rusty metal sunroof.
By the way, it seems the most rusty part is a sunroof in my case... it is a 12 years old car...
Old Apr 10, 2004 | 10:01 AM
ph8ed4life's Avatar
very nice...wish I would have looked closer and figured this out, cause I had a 5th gen sunroof laying around!! Oh well...
Old Apr 10, 2004 | 10:07 AM
satan_srv's Avatar
Default Re: GLASS Sunroof for a 4G Lude?! (ph8ed4life)
The glass is defintely heavier.
