Cam Gear Whining
Old Oct 26, 2001 | 01:45 PM
Tomakit's Avatar
Default Cam Gear Whining
My stock cam gears whine like there is no tomorrow. Any ideas on what this could be? It sounds like a bearing is shot, but there are no bearings that I am aware of.
Tom
Old Oct 26, 2001 | 02:04 PM
non-VTEC's Avatar
Default Re: Cam Gear Whining (Tomakit)
timing belt tensioner.....
Old Oct 26, 2001 | 02:43 PM
Tomakit's Avatar
Default Re: Cam Gear Whining (non-VTEC)
that's what ive been told. any way to quasi-easily access this?
(without doing basically an entire timing belt change?)
Tom
Old Oct 26, 2001 | 02:58 PM
non-VTEC's Avatar
ummm........easy way to replace it.........bassically you gotta remove the crank pulley and the upper and lower timing belt covers...........then from the wheel well you will see the tensioner. take out the 14mm bolt and remove the tensioner. make sure you dont loose the spring.
another 15min of work you could have the belt off too.........might as well change it........
Old Oct 26, 2001 | 03:10 PM
Tomakit's Avatar
DOH!
Just had a friend swap a new motor in the car and throw a new timing belt on (300 miles ago). So i dont need to change it, just loosen it up some.
Tom
Old Oct 27, 2001 | 04:47 AM
non-VTEC's Avatar
so you probably dont need a new tensioner. you just need to re-adjust the current tensioner/belt. maybe you have it on to tight......
Old Oct 27, 2001 | 11:11 AM
RedlinedVTEC's Avatar
Loosen the tensioner bolt 180 degrees and then manually rotate the engine over 5-10 times to get the timing belt to tighten up, once you remove any excess play tighten the tensioner up and you're on you way. Shouldn't take more than 5 minutes max. HTH
Ben
Old Oct 27, 2001 | 05:34 PM
GruvyTune's Avatar
New User
Default Re: Cam Gear Whining (RedlinedVTEC)
Is it normal to have increase play in the belt if you turn the crank pulley the opposite way (clockwise) from its normal rotation?
thebleek
Oct 1, 2008 02:39 PM
NoVALude
Jul 19, 2006 11:53 AM
hondaeg8
11
Oct 4, 2004 08:49 AM
zueke
Nov 28, 2003 08:38 PM
sivik2nr
Jun 3, 2003 07:43 AM
