compression test results
92 Prelude SI 4ws, H23a engine. Cars burns oil bad, inside exhaust coated with oil.Compression test results
1-230
2-230
3-220
4-230
Is compression good and if so whats wrong with engine? Engine has 98,000 miles
1-230
2-230
3-220
4-230
Would anything other than carbon buildup cause high compression? Just went out and did another compression test and the #.s came out the same.
the reason why the numbers are high is due to one that the carbon and oil deposits built up on the pistons. but mainly due to the amount of wet oil in the cylinders. wet oil, aka a wet compression test will drastically change the compression upwards to 30 psi.
a wet compression test is when you put oil intentially into the cylinders on a car with low compression. if the compression raises then you know that the rings are bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer »</TD></TR><TR><TD CLASS="quote">Wet compression test deals with piston rings, not the carbon build up.</TD></TR></TABLE>
my point exactly. the amount of oil in his cylinders will increase the compression.
