cylinder honing?
Old Apr 6, 2004 | 10:12 PM
obd1gsr's Avatar
Default cylinder honing?
i have a 95 gsr with 69k miles on it i wanna swap jdm b16 pistons and head on it. will i need to hone the cylinders? is it hard? can i do it myself? if not how much would it cost?
Old Apr 6, 2004 | 10:14 PM
mmuller's Avatar
Mad Scientist
Default Re: cylinder honing? (obd1gsr)
yes if you change pistons/rings you need to hone, yes you can do it yourself if you know what you are doing, but a machine shop will do it for cheap
Old Apr 7, 2004 | 05:44 AM
obd1gsr's Avatar
Default Re: cylinder honing? (mmuller)
do you think at 69k miles my cylinders might have to be bored a little?
Old Apr 7, 2004 | 07:12 AM
torr's Avatar
no it shouldn't need to be bored. bore the cylinders if there are any deep scrachtes on the cyl. walls. deep enough to catch a finger nail on when you run you fingers along the walls. scratches that you can see but not feel only need to be honed.
autoparts stores sell a cyl honing tool that attaches to a drill. all you need to do is use some automatic tranny fluid to help lube the walls and then use the drill and the honing tool in a up and down motion to hone the cyl. clean walls thoroughly and make sure you clean the crank also if it is gonna still be installed.
Import RP
Mar 24, 2006 03:38 AM
danthemang3
Jan 14, 2006 06:21 PM
boosted k20
Sep 28, 2004 06:53 AM
1RMDave
Nov 14, 2002 01:28 PM
xjohnx
Jan 20, 2002 10:54 PM
