Piston install question
Old Jan 18, 2002 | 07:33 PM
xjohnx's Avatar
Default Piston install question
is it necessary to bore out the block when installing pistons on a fresh motor? my motor only has 12k miles on it but if i have to take it out and have it bored out it's not really worth the money to do so... i remember reading that if it was this fresh you can just scuff up the cylinder walls a little? anyone got any advice?
Old Jan 18, 2002 | 07:53 PM
Toda Party's Avatar
Default Re: Piston install question (xjohnx)
u can hone the cylinder walls, or u can bore it, its up to u..u don't HAVE to bore
Old Jan 18, 2002 | 07:56 PM
TODAwhore's Avatar
Default Re: Piston install question (Toda Party)
yeah just save your money and hone it...very easy to do.
xjohnx's Avatar
what all is entailed in honing it? is that something that can be done while in the car still?
Old Jan 18, 2002 | 08:02 PM
Toda Party's Avatar
the procedure is in the helm's...u need a honing stone and hone the walls in a 60 degree triangle pattern....
i dont think i'd try it by myself...and im pretty sure u have to pull the motor
Old Jan 18, 2002 | 10:24 PM
JPP's Avatar
JPP
I change my pistons myself last summer and honed the cylinder wall with a honing tool that you can buy and fit in a regular hand drill. You have to use at least 400 grit stones and the procedure is only to clean the wall surface and make a diamond shape pattern (I guess it is to help the oil cling to the wall and lubricate better) Keep in mind that you don't want to increase the cylinder diameter so don't hone to long.
Old Jan 18, 2002 | 10:42 PM
sgT's Avatar
sgT
If you are off in the honing, then it will smoke and burn oil.
Do it right and take it out to a machine shop.
Old Jan 19, 2002 | 01:07 AM
dohcgarage's Avatar
Default Re: Piston install question (sgT)
so SGT, are u saying that he should bore it out? or don't hone it himself and have a machine shop hone it?
Old Jan 19, 2002 | 01:09 PM
TODAwhore's Avatar
Default Re: Piston install question (dohcgarage)
honing is easy i'm sure you can find a friend to help you out...also if thats all you are doing is installing new pistons then you can just leave the motor in the car...just be sure to clean the cylinder walls with warm soapy water, then make sure there is no more grit from honing in the bottom of the walls and re-oil them down really good and you should be ready to go..
Old Jan 19, 2002 | 01:23 PM
sgT's Avatar
sgT
I always recommend overbore, but i was i was primarily referring to honing.
and yes, i strongly recommend taking it to a machine shop to hone.
Old Jan 20, 2002 | 09:01 PM
KayOs's Avatar
Can you recommend some top notch machine shops in USA? preferrably with experience with B series Honda engines. Thanks.
Old Jan 20, 2002 | 10:54 PM
Toda Party's Avatar
Default Re: Piston install question (KayOs)
portflow does good headwork..or is one of the more popular ones.
mike K reccommended someone last time, i think it was topspeed?
also, i dunno, im jus throwing this name out...DRT? Dunno anything about them tho
turboman2.2
Feb 12, 2010 12:43 PM
typeSwarrior
Jul 28, 2007 05:19 PM
ACrite3404
Dec 12, 2004 10:38 PM
JDMotive
May 28, 2004 02:26 PM
lopey
Aug 16, 2002 04:23 PM
