Lightweight FLYWHEEL with STOCK clutch?
Old Apr 5, 2004 | 03:52 PM
B00ST2nR's Avatar
Default Lightweight FLYWHEEL with STOCK clutch?
Is it ok to get a lightweight Flywheel and stick with the stock clutch?
My stock clutch is in perfect condition and have no reason to swap it out... but I wanna get a lighter flywheel. Will this be ok?
Old Apr 5, 2004 | 04:11 PM
tilt's Avatar
Default Re: Lightweight FLYWHEEL with STOCK clutch? (Skunk2nR)
i dont see anything wrong with it
Old Apr 6, 2004 | 06:39 PM
thegsrman's Avatar
i had clutchmasters flywheel and stock clutch on my last gsr and it worked fine. there were no problems. so i don't see why not.
Old Apr 6, 2004 | 07:05 PM
HondaGuy02's Avatar
Banned
Default Re: Lightweight FLYWHEEL with STOCK clutch? (thegsrman)
youll be fine, i plan on just getting my stock flywheel lightened
thats another route you can go.
Old Apr 6, 2004 | 07:26 PM
Kal's Avatar
Kal
Default Re: Lightweight FLYWHEEL with STOCK clutch? (HondaGuy02)
don't think you should lighten your stock flywheel.. it'll throw off the balance and it wasn't engineered to have material removed from it, therefore, structural integrity of the disk might be jeopardized.
Old Apr 7, 2004 | 10:05 AM
88 turbo crx's Avatar
Default Re: Lightweight FLYWHEEL with STOCK clutch? (Kal)
You can remove weight safely, its just a matter of how much and making sure its balanced afterwards. You wont have any problems using a stock disk with a lightened flywheel.
Old Apr 7, 2004 | 07:02 PM
HondaGuy02's Avatar
Banned
Default Re: Lightweight FLYWHEEL with STOCK clutch? (88 turbo crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">don't think you should lighten your stock flywheel.. it'll throw off the balance and it wasn't engineered to have material removed from it, therefore, structural integrity of the disk might be jeopardized.</TD></TR></TABLE>
good point... , but as long as you get everything balanced together after its lightened... why would there be a problem.
Modified by HondaGuy02 at 10:12 PM 4/29/2004
Old Apr 21, 2004 | 10:24 PM
B00ST2nR's Avatar
I heard it can wear your stock clutch really fast. Yes?
rick_rabies
Jul 11, 2009 10:40 AM
mitcho
Sep 22, 2008 12:38 PM
tweekerz
Jul 28, 2006 07:43 PM
allmotorek8
10
Nov 3, 2005 06:37 PM
Dc_John
Apr 2, 2004 07:57 PM
