Cant get rid of Engine Ping
Old Apr 4, 2004 | 07:11 PM
DC 2's Avatar
Default Cant get rid of Engine Ping
Ive retarded the timing to 16btdc, Ive added fuel additive and 93 octane and this damn engine still pings like a champ. any ideas would help greatly
Old Apr 4, 2004 | 07:30 PM
SkRiBLaH's Avatar
Default Re: Cant get rid of Engine Ping (EH3B18B)
any details on spcifics of what engine this is??
mods?
when does it ping?
Old Apr 4, 2004 | 08:49 PM
DC 2's Avatar
Default Re: Cant get rid of Engine Ping (SkRiBLaH)
The motor is a First Gen B16 and It only pings under load. It is completely Stock. Im running some Boush plugs...
Old Apr 4, 2004 | 10:57 PM
Redline130's Avatar
I would change those plugs and use some NGK's. Have you checked and adjusted your valves? If not, I would check that out as well. Maybe you have a lot of carbon built up on either the valves and/or the pistons.
Old Apr 4, 2004 | 11:39 PM
civickiller's Avatar
Default Re: Cant get rid of Engine Ping (Redline130)
try adjust your valves
Old Apr 5, 2004 | 08:59 AM
suspendedHatch's Avatar
Default Re: Cant get rid of Engine Ping (civickiller)
Have your fuel injectors serviced.
Get an aftermarket oil catch can.
Old Apr 5, 2004 | 10:45 AM
spaceman's Avatar
change your fuel filter also and get rid of those plugs and get some ngk's
Old Apr 5, 2004 | 01:49 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH3B18B &raquo;</TD></TR><TR><TD CLASS="quote">Ive retarded the timing to 16btdc, Ive added fuel additive and 93 octane and this damn engine still pings like a champ. any ideas would help greatly</TD></TR></TABLE>
what ecu are you using? and is it reprogrammed?
Old Apr 5, 2004 | 07:35 PM
DC 2's Avatar
Default Re: Cant get rid of Engine Ping (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
what ecu are you using? and is it reprogrammed?</TD></TR></TABLE>
Using the stock PR3, I didnt go with the NGK's cause the only plugs they had in stock were iridium plugs and they wanted 10-15bux a piece.
Old Apr 5, 2004 | 07:40 PM
Syner-G-Racing LLC's Avatar
like they said before, oil catch cans rock, the cleaner the better, and if its not just carbon build up its problay worn guides
Old Apr 5, 2004 | 07:44 PM
tilt's Avatar
well if you are pinging id retard it even more, at least temporarily til you figure out what's up. also just to name another one of many possibilities, i remember someone saying that if you are using a smaller fuel rail (possibly a dseries?) then it can cause problems with fuel delivery.
Old Apr 5, 2004 | 08:19 PM
DC 2's Avatar
Default Re: Cant get rid of Engine Ping (tilt)
I have the ign timing as far as it will go on the dizzy. Im also using a timing light. I dont think an oil catch can will fix the problem. I know its not the valves making the noise. How could the valve seals create detonation? Should I try some SeaFoam to rid of excess carbon?
Old Apr 5, 2004 | 09:24 PM
Combustion Contraption's Avatar
as far as trying seafoam id give it a shot, its already pinging,what have u got to lose? i also dont think an oil catch can would fix the problem, but theyre good to have nevertheless...
Old Apr 5, 2004 | 11:35 PM
Default Re: (LsVtec92Hatch)
u should try and adjust your valves, its free to do, only requires time, well maybe a new valve cover gasket.
Old Apr 6, 2004 | 01:49 AM
kchungb17a's Avatar
Default Re: (civickiller)
Are we sure it's pinging we're hearing? A loose timing belt can cause a pinging like noise that can really mess with your head...
I hate the night shift!
Prudz_lude
Jun 5, 2007 03:21 PM
projektcivic
Dec 14, 2006 09:39 AM
gitwidit
Mar 17, 2006 06:52 AM
1 SiC EJ1
Jun 5, 2005 07:59 AM
nY's FiNeSt
12
Apr 23, 2004 06:51 AM
