ABS light???
Old Apr 3, 2004 | 05:28 PM
Ls-Rturbo's Avatar
Default ABS light???
I just finished swaping a 96gsr tranny in my 99Ls it all went pritty good except i messed up my ball joint and had to take the knuckle off to get the new ball joint pressed in, im a running a stock obd-1 ecu. what the heck could make my abs light stay on????
Old Apr 3, 2004 | 06:22 PM
Ls-Rturbo's Avatar
Default Re: ABS light??? (bl18t)
anyone
Old Apr 3, 2004 | 08:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote"> what the heck could make my abs light stay on????</TD></TR></TABLE>
What code does it have stored?
Old Apr 4, 2004 | 10:35 AM
Ls-Rturbo's Avatar
Default Re: ABS light??? (Chiovnidca)
there is no check engine light on just abs. how would i check the code for the abs light?
Old Apr 4, 2004 | 10:38 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">there is no check engine light on just abs. how would i check the code for the abs light?</TD></TR></TABLE>
Same as a CEL.
Old Apr 4, 2004 | 11:55 AM
Ls-Rturbo's Avatar
k im gonna try it now
Old Apr 4, 2004 | 10:36 PM
Ls-Rturbo's Avatar
well i put a diffrent axle in i guess i must have had an non-abs one
Old Apr 5, 2004 | 02:57 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">well i put a diffrent axle in i guess i must have had an non-abs one</TD></TR></TABLE>
What was the code? Does the axle have sensor ring on it?
Old Apr 5, 2004 | 08:47 AM
Ls-Rturbo's Avatar
Default Re: ABS ?light?? (Chiovnidca)
well i dident put the new axle in yet but I have allready got it. I tryed to check the code but but when i pluged in the paper clip to the plug in the green holder by the ecu the check engine light stays on when the paper clip is in(neather the abs or check engine light blinks) I think it has to be somthing to do with the driver's side suspention because when i first swaped the tranny the light was out but shortly after I had to replace the axle and ball joint and sence the light has bin on
Old Apr 5, 2004 | 02:01 PM
Chiovnidca's Avatar
Default Re: ABS ?light?? (bl18t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote"> when the paper clip is in(neather the abs or check engine light blinks) </TD></TR></TABLE>
That means there are no trouble codes stored. Did you run the engine with the wheels turning off the ground? If so the light should go out after a short drive.
typeR564
Feb 26, 2007 10:35 PM
Type_R_Lover
Nov 7, 2006 09:10 AM
FatBoy4door
Oct 7, 2004 10:21 PM
jweezy225
Aug 5, 2004 09:56 PM
GSblueRacing
May 6, 2003 09:21 PM
