searched....rear hatch not working
Old Apr 3, 2004 | 08:41 AM
sinatra's Avatar
Default searched....rear hatch not working
1998 GS-R.
Problem: Rear hatch won't open via switch when doors are unlocked. It will work though when the key is used on the hatch.
Remedy: Here is what I have done so far. Replaced actuator for the hatch.
Problem is still there. It seems like it isn't recognizing that the door are unlocked.
Has anyone had this problem and remedied it? What lines would I run a continuity test between to be sure the actuator is receiving a signal?
Thanx guys
EDIT: Problem appears to be in the switch. Anyone have any experience with this? Come on guys I know I am not the only one that has had this problem.
as a side note. I did search this and I found one thread with a bunch of BS answers. So maybe I can get some intelligent ones here.
Modified by sinatra at 10:52 AM 4/3/2004
Old Apr 3, 2004 | 09:52 AM
sinatra's Avatar
Default Re: searched....rear hatch not working (sinatra)
bump for a reply or two pertaining to this problem.
Old Apr 3, 2004 | 10:05 AM
FastSS's Avatar
I take it they changed from ye old pull latch like on the 95s eh
Old Apr 3, 2004 | 02:05 PM
sinatra's Avatar
Default Re: searched....rear hatch not working (FastSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastSS &raquo;</TD></TR><TR><TD CLASS="quote">I take it they changed from ye old pull latch like on the 95s eh</TD></TR></TABLE>
From what I understand of your question yes the 98 integras have a different latch system than the 94-97? integras. There is no hatch release up front, only at the rear in the hatch itself.
Old Apr 3, 2004 | 04:39 PM
DigitalPunk's Avatar
Mine does'nt work either, but Im pretty sure I have a bad actuator cuz I can hear the relay click when i pull the switch. I have'nt done much more investigating other than that. I may look at it tomorrow and let you know if I find anything else. BTW, wanna sell me that extra actuator if I need it?
Old Apr 3, 2004 | 08:03 PM
iwannaboostmyteg's Avatar
Default Re: searched....rear hatch not working (DigitalPunk)
Yeah I need to know the answer to this problem as well because my 98 only works like 1 out of every 10-20 times I usually just use the key and don't even bother trying to hope it will work. But like you said you can hear the click of it but it just doesn't release the locking mechanism.
Old Apr 3, 2004 | 08:10 PM
Ti3d in's Avatar
Default Re: searched....rear hatch not working (iwannaboostmyteg)
I have this exact same problem. Have no idea how to fix it either.
Old Apr 3, 2004 | 10:32 PM
sinatra's Avatar
Default Re: searched....rear hatch not working (Ti3d in)
Well if you hear a click it is most likely the actuator. If you don't hear click it is most likely the switch. More on this when I get the switch though.
Old Apr 4, 2004 | 09:22 AM
{Mineral Grey} ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra &raquo;</TD></TR><TR><TD CLASS="quote">Well if you hear a click it is most likely the actuator. If you don't hear click it is most likely the switch. More on this when I get the switch though. </TD></TR></TABLE>
Good response......
Old Apr 5, 2004 | 06:51 AM
Default Re: searched....rear hatch not working (98 (ITR) Theft Recovery)
No, its the relay that I hear clicking, on the drivers side of the car, behind the little trunk light.
Old Apr 5, 2004 | 07:01 AM
sinatra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DigitalPunk &raquo;</TD></TR><TR><TD CLASS="quote">No, its the relay that I hear clicking, on the drivers side of the car, behind the little trunk light. </TD></TR></TABLE>
Hmm. I haven't seen a relay back there. I have seen an actuator though. I do tend to miss stuff like that though.
Old Apr 5, 2004 | 07:05 AM
spark plugs.
Guest
Posts: n/a
BUMP for someone with a good solution...but it wouldn't hurt to walk into an acura service center and ask them...maybe you're not the only one with this problem.
Old Apr 5, 2004 | 07:10 AM
redGSRguy's Avatar
Default Re: searched....rear hatch not working (troublecodes)
I have a similar problem, I hear something clicking when I pull the switch but the hatch won't come up. The only way i can open it is to stick the key in turn it, and jiggle the switch furiously.
Old Apr 5, 2004 | 12:16 PM
sinatra's Avatar
Have friends who work at both Honda and Acura. They say the same thing I say. Looking for a swicth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar problem, I hear something clicking when I pull the switch but the hatch won't come up. The only way i can open it is to stick the key in turn it, and jiggle the switch furiously.</TD></TR></TABLE>
Sounds like the actuator bro.
Old Apr 5, 2004 | 12:26 PM
01DC-2's Avatar
i kinda have the same problem, but mine does not lock?! when i try to close the hatch up, it just jumps back up, as if something was in the way. if i hit the switch 4or5 times something comes loose, then it is able to lock?..
anyone have that problem?
deejaycherub's Avatar
sounds like an acura defect... there sure are a lot of these .. including mine... but i have no problem with it. i just think of it as better security...
Old Apr 5, 2004 | 02:01 PM
sinatra's Avatar
Default Re: searched....rear hatch not working (01DC-2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01DC-2 &raquo;</TD></TR><TR><TD CLASS="quote">i kinda have the same problem, but mine does not lock?! when i try to close the hatch up, it just jumps back up, as if something was in the way. if i hit the switch 4or5 times something comes loose, then it is able to lock?..
anyone have that problem?</TD></TR></TABLE>
That's a new one. I would say maybe the locking mechanism is falling back and closing while the hatch is up? Just a guess.
Old Feb 6, 2009 | 06:37 AM
Muad'Dib's Avatar
Corr Performance Pilot
seems like i'm also having this problem. how involved is it in getting back there to the actuator and getting it fixed? should i buy the actuator from Acura right now and then start the work?
Old Feb 6, 2009 | 08:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
sure are bumping alot of old threads lately. I thought search was disabled right now....
Anyway getting to the actuator should be as simple as pulling the plastic trim piece out of the back side of the cargo area.
Old Feb 6, 2009 | 09:15 AM
Muad'Dib's Avatar
well, not really bumping but just posting to see if folks can help out. The search is DEFINITELY not disabled, at least for me it isnt. hehehehe. Kewl, if its that simple then I'll tackle that before the DASH situation. EEEK!!
redacura
Sep 26, 2005 07:33 PM
1999gs-r
Mar 10, 2005 08:06 AM
OnePointFive
Jun 18, 2004 11:08 PM
Alexander
May 24, 2002 01:03 PM
InfamousRS
Jul 2, 2001 12:39 PM
