DA radiator
Old Feb 5, 2009 | 10:58 AM
95_red_dc's Avatar
Default DA radiator
Would a da radiator fit in a ef?
Old Feb 5, 2009 | 11:24 AM
neardon's Avatar
I'm a Jackass
Default Re: DA radiator
Its not going to bolt right up, you will probably have to do a custom mounting job. Is it just the single cam in the EF? if it is it will fit for sure but if its swapped or turbo you might run into some problems.
Old Feb 5, 2009 | 04:14 PM
95_red_dc's Avatar
Its got a b16 swapped in it.
Old Feb 5, 2009 | 04:27 PM
seanbev24's Avatar
Why do you want to put a DA radiator in an EF? Most of the people I know with DA's want the half size radiator lol.
Assuming the header clearance isn't an issue, I think you would just need to move one or both of the bottom mounts and make a little bracket for the top.
Old Feb 5, 2009 | 11:11 PM
bobbyisking's Avatar
i believe it is a direct fit, other than the larger inlet and outlet. i believe the stock hoses will fit, but will be extremely tight. i sold my spare DA radiator a week before i bought my crx, dammit.
Old Feb 6, 2009 | 06:00 AM
be18see1's Avatar
It fits just fine, and I'm about 75% sure it will bolt right up. You will most likely want to pick up some new hoses though because the diameter of the stockers is too small.
Old Feb 6, 2009 | 10:31 AM
seanbev24's Avatar
It's too bad you guys wanting a DA radiator are so far away, I'll have a good one available in a few days since I'm switching to a half width fluidyne
alexEF
33
Apr 6, 2010 09:26 AM
EF9_RIDER37
Apr 3, 2010 08:57 PM
bigcivman09
Feb 22, 2009 06:22 AM
djay86
May 23, 2003 12:30 PM
