White smoke/Compersion test Read
Old Apr 3, 2004 | 05:35 AM
calvinPGMFI's Avatar
Default White smoke/Compersion test Read
I boosted yesterday 7-8psi on a b16a2(second gen)
Suddenly 3 cylinders. Towed my car home.
This moring compersion test.
Cyl 2&3 200 psi. Cyl 1 10 psi Cyl 4 50psi.
White smoke out of the valve breather. White/blake smoke out of the exhaust.
Is this the symtons of the blow head gasket or pistons with a crack.
calvin thanks
Old Apr 3, 2004 | 05:43 AM
Flr Power's Avatar
Default Re: White smoke/Compersion test Read (calvinPGMFI)
Blown ring land for sure. Take the head off.
Old Apr 3, 2004 | 05:50 AM
Default Re: White smoke/Compersion test Read (coocoo32)
i will take the head off how can i check the rings? need to pull the pistons out.
Old Apr 3, 2004 | 09:28 AM
FragSyndrome's Avatar
yea, you need to pull the pistons.
That shouldn't have happened though. Were you running it untuned or something? What was your setup?
Old Apr 3, 2004 | 09:59 AM
Harassing Herbs's Avatar
Default Re: (FragSyndrome)
hopefuly your cyclindar walls are not scored too bad so you don't have to drop extra cash to get it bored.
same thing happened to me but 3 weeks after turbo install white smoke coming out the breather filter & dip stick hole, not too bad. car still runs but kind of sounds like a wrx. you can hear one cyclindar loosing some compression. gotta wait for my parts to come this week so i can put together my spare block.
im running fmu untuned ( i know it sucks ) but it was only going to be for a month or 2. i believe it was when my oil pump died out on me 10 miles from home. drove it home ( like a dummy) replaced the pump
10 days later smokey engine.
Old Apr 3, 2004 | 10:26 AM
I have a ecu chip.
with retard and fuel etc, 440 injector.
I more ecu guy. I'm making a logger right now.
Calvin
Old Apr 3, 2004 | 10:32 AM
7-8 psi.
I have my own chip. My boostcode a little different the uberdata and crome.
I was runnning 1.35 retard/145% fuel 440cc injector
i have boostcut a 9 psi. So the boost never went above 9 psi.
Calvin It was not untuned under boost always openloop. Which was a bug in old boost chips. but mine doesn't have that
wanna see my logger
ragethemachine86
Oct 3, 2006 09:33 AM
bukbukintegra
May 17, 2005 04:45 PM
Teal95Coupe
Mar 29, 2005 07:50 PM
SIK IN DA HED
Mar 23, 2003 02:09 PM
All Motor EG
Jul 22, 2002 09:48 AM
