Ok one more rear sway bar question
Old Apr 1, 2004 | 01:52 PM
jtl's Avatar
jtl
Default Ok one more rear sway bar question
I can get some si rear lower controll arms for $65 a piece. And I can get the Si rear sway bar for $60. Should I go for it? Or should I get the control arms and aftermarket sway bars. Do I really need to upgrade the front bar? Thanks
-Jake
Old Apr 1, 2004 | 01:54 PM
JCracer723's Avatar
Default Re: Ok one more rear sway bar question (jtl)
just go to your local junkyard .. you can get them cheaper
Old Apr 1, 2004 | 02:17 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtl &raquo;</TD></TR><TR><TD CLASS="quote">I can get some si rear lower controll arms for $65 a piece. And I can get the Si rear sway bar for $60. Should I go for it? Or should I get the control arms and aftermarket sway bars. Do I really need to upgrade the front bar? Thanks
-Jake</TD></TR></TABLE>
thats pricey, and upgrading the front bar is generally not what you want to do if you want to eliminate understeer
Old Apr 1, 2004 | 02:29 PM
phan's Avatar
Default Re: Ok one more rear sway bar question (temp)
understeer = the enemy.
Old Apr 1, 2004 | 02:54 PM
katb16vo's Avatar
Default Re: Ok one more rear sway bar question (phan)
whoa 65$ a piece? i'll hook you up with integ gsr rear sway bar + the LCAs for 40$ but it is 14mm but i did get my si LCA and rear sway bar for 80$ all together
Old Apr 1, 2004 | 03:51 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan &raquo;</TD></TR><TR><TD CLASS="quote">understeer = the enemy. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=803608
Old Apr 1, 2004 | 04:10 PM
phan's Avatar
Default Re: Ok one more rear sway bar question (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=803608</TD></TR></TABLE>
care to explain that? that whole discussion was front sway v. no front sway...where did it say that understeer WAS a good thing?
Old Apr 1, 2004 | 04:19 PM
JCracer723's Avatar
care to explain that? that whole discussion was front sway v. no front sway...where did it say that understeer WAS a good thing?</TD></TR></TABLE>
i am not saying and no1 is saying that understeer is a good thing but:
for some reason everyone thinks a front swaybar will cause understeer 100% of the time. in a perfectly balanced rear drive car, ok. in a front heavy, fwd car there are a large number of other factors that are contributing to understeer. you can band-aid by removing the front bar, then band-aid the increased roll by adding more spring rate, then band-aid the spring rate with different shock valving, etc. until you fix the real problem all you'll be doing is throwing band-aids at a severed artery. &lt;&lt; quoted from that thread
Old Apr 1, 2004 | 04:24 PM
phan's Avatar
yes, i read that thread. i don't recall having said that no front sway bar is better, though. personally, i'd be happy with an HF front sway bar.
918eg
Sep 4, 2008 02:05 PM
andyvaj
Mar 18, 2005 09:51 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
Dorikamu
Oct 25, 2002 01:01 PM
