strut and sway bar help
I'm buying a set of strut and sway for my EG and my question is
where about do i find the spot for sway bar both front and rear?
Re: strut and sway bar help (918eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918eg »</TD></TR><TR><TD CLASS="quote">I'm buying a set of strut and sway for my EG and my question is
where about do i find the spot for sway bar both front and rear?</TD></TR></TABLE>
they connect to your lower control arms (LCA's), you're going to need LCA's that have holes for a sway bar to bolt up to though.
should should be ok with the rear sway bar, Your rear stock LCA's should have the holes for the rear sway bar. for the front im not sure, but when i did mines to my ej6, i needed to change out the front LCA's and the forks.
Re: (rpared01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 »</TD></TR><TR><TD CLASS="quote">should should be ok with the rear sway bar, Your rear stock LCA's should have the holes for the rear sway bar. for the front im not sure, but when i did mines to my ej6, i needed to change out the front LCA's and the forks.</TD></TR></TABLE>
you're wrong. stock eg rear LCA's do not have sway bar mounting holes. I'm unsure of the front because my del sol si came with a front sway bar (21mm)
p1driftfiend
14
02-23-2004 12:18 PM
