WHat should I do with my Y8 "Please be critical"
I have a d16y8 that I am wanting to boost up to like 200 WHP and I am trying to find out what kind of upgrades I need to do to my motor to make this happen. I am wondering is the head and valve train good up to 200 or do I need to get a cam and valve train that is better. Also this is a daily driver so what kind of pistons and compression ratio do I need. I have a guy trying to sell me a T25 for 40 dollars so this is what sparked this idea. Also will I need an intercooler. How many HP will my stock crank hold up to or do I need a better one. Pretty much what internals do I need to upgrade to get 200 on a daily driven car. Also what kind of headaches will I run into wikth a T25 or should I buy a different one. Thanks
James
James
You do not need to do any motor work to support 200whp in a D series. First step is to make sure you have all your general maintenence done. This includes water pump, timing belt, thermostat, etc. Then grab up a turbo kit with an intercooler, bov, and good fuel management. Most daily driver sized turbos on the D series put out 200whp at around 10 pounds, but it will vary on the size of the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pollito »</TD></TR><TR><TD CLASS="quote">You do not need to do any motor work to support 200whp in a D series. First step is to make sure you have all your general maintenence done. This includes water pump, timing belt, thermostat, etc. Then grab up a turbo kit with an intercooler, bov, and good fuel management. Most daily driver sized turbos on the D series put out 200whp at around 10 pounds, but it will vary on the size of the turbo.</TD></TR></TABLE>
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
leave your motor stock and buy a turbo kit, new or used for about a grand. I have a greddy turbo kit, and I love it. Got it used for 900 bucks. Shop around.
You might wish you had a bigger turbo tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnar »</TD></TR><TR><TD CLASS="quote">WHat is the best D block to turbo. Or are they all about the same.</TD></TR></TABLE>
Y8 or Z6.
Y8 or Z6.
i like the a6 block...but they are all same basically, i did 205whp on 6psi with 1300 bucks, built my own kit and used plenty of mitsubishi parts, fuel pump, 450's, IC, made own ic piping, dp, benefits of having a father who is a welder....Went with a t3 super 60 I like the turbo alot and it makes awesome power, very efficent...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi »</TD></TR><TR><TD CLASS="quote">i like the a6 block...but they are all same basically, i did 205whp on 6psi with 1300 bucks, built my own kit and used plenty of mitsubishi parts, fuel pump, 450's, IC, made own ic piping, dp, benefits of having a father who is a welder....Went with a t3 super 60 I like the turbo alot and it makes awesome power, very efficent...</TD></TR></TABLE>
A6 is a good block too, if you use the A6 pistons you may want to look into some engine management for some good tuning though. A6 pistons will give you higher compression than the Z6 or Y8.
216Resident
30
Aug 1, 2017 05:16 AM
AceGates
19
Mar 20, 2010 11:00 PM
