temperature gauge problem
Old Apr 1, 2004 | 04:57 AM
canzures's Avatar
Default temperature gauge problem
Hi all,
i have had my 95 gsr for only 3 days and I was wondering if there was a problem with my cooling system. the needle on my temperature gauge even when it is at normal operationg temperature stays pretty close to the cold range like about a quarter of an inch from the cold range. I have a 97 gs that I've had for a year and it's needle at operating temperature is almost at the middle. I'm wondering if my gsr has a cooling problem that I should fix immidiatelly. like replacing the thermostat, drain and replace the coolant?
thanks in advance
Old Apr 1, 2004 | 05:49 AM
SuzukaBlueAP2's Avatar
Default Re: temperature gauge problem (canzures)
It's the thermostat. If the car stays that cold, then the thermostat is stuck open.
Old Apr 1, 2004 | 05:51 AM
ebelp's Avatar
Default Re: temperature gauge problem (ScreaminTeg)
It's normal. My temp. guage has never gone past the 1/4 mark, but most of the time, it stays almost all the way towards the cold side.
Old Apr 1, 2004 | 06:23 AM
Default Re: temperature gauge problem (ebelp)
I wouldn't call it normal. If the cooling system is stock, then the needle should almost go to the halfway point.
There is such a thing as the engine running too cold. It needs to reach an operating temperature in order to run correctly. If the needle is barely moving up, and the cooling system is stock, the thermostat should be replaced. It's cheap and easy to do.
Old Apr 1, 2004 | 10:16 AM
canzures's Avatar
i was thinking that the thermostat was faulty. I'll change that this weekend and see what happens. thanks for the info
Old Apr 1, 2004 | 10:18 AM
Audi A4's Avatar
mine sits at a little past 1/4
Old Apr 11, 2004 | 11:21 AM
TurboTeG4's Avatar
Default Re: temperature gauge problem (DRAG lll INTEGRA)
So it would be the thermostat, where is the switch that sends to the gauge, is it the one by the lower radiator hose by the head.
Old Apr 11, 2004 | 01:21 PM
TurboTeG4's Avatar
Well I changed my thermostat, and my gauge still dont work and my fan dont come on. There is 2 ect sensors on in the front on the head and one in the back on the thermostat housing. Which one controls the fan?
Old Apr 11, 2004 | 01:51 PM
xplanetearth420x's Avatar
Default Re: temperature gauge problem (TurboTeG4)
mine is a lil past the 1/4 mine also
Old Apr 11, 2004 | 05:27 PM
TurboTeG4's Avatar
Default Re: temperature gauge problem (xplanetearth420x)
Oh yeah and my heater dont work whats up with that it blows cold
Old Apr 12, 2004 | 05:41 PM
IVI's Avatar
IVI
thermostat. it prevents your car from warming up when stuck open since the anti-freeze keeps cooling your engine wihtout warming up first. however if your gauge is reading false.. it could be the gauge, or air in the coolant lines.. tricking the gauge into thinking the car isnt overheating when it really is..
Weak!EG
Feb 16, 2010 05:41 PM
typeRobtypeS
Nov 20, 2005 08:02 PM
ButterMule
Nov 27, 2004 10:19 AM
powerls
Jan 27, 2004 04:32 PM
Sir_Phobos
Dec 7, 2002 08:45 AM
