which suspension setup would you get for an EP3?
Old Mar 31, 2004 | 07:35 PM
Ya@inlinePRO's Avatar
Default which suspension setup would you get for an EP3?
I'm still considering an EP3 and doing some research about the suspension possibilties. I've read about the issues with KONI yellows, which is what i wanted, but after reading about it, i sort of don't want it anymore hehe. Is there any coilover setup out there where it WON"T involve any modifications to fit? if so , which ones have you driven on, and what do you like and not like. I'm also looking to do a lot of auto-x.
so far i've got in mind are the TEIN Flex, but they said its only for 03+ si, what about 02's?
Old Apr 1, 2004 | 03:36 AM
Yeung's Avatar
Default Re: which suspension setup would you get for an EP3? (kwik2nec)
to the best of my knowledge.. tein flex are not too street friendly.. they are more of a track suspension..
Old Apr 1, 2004 | 03:48 AM
combustion's Avatar
Default Re: which suspension setup would you get for an EP3? (Yeung)
I would stick with the flex they are quality and as for the atreet just put them on the softest setting should be fine. If you are looking to buy a 03 ep3 contact me I have one for a great price
Old Apr 1, 2004 | 04:05 AM
Default Re: which suspension setup would you get for an EP3? (combustion)
any fitment issues? why won't the 03's fit the 02's? or do they?
Old Apr 1, 2004 | 04:07 AM
ep3minivan's Avatar
they fit the 02.
Old Apr 1, 2004 | 06:13 AM
Boilermaker1's Avatar
JIC FLT-A2s compare to the Flex. They're in my car, I autoX on them, they're great for that, but they take some getting used to on crappy roads... they're pretty stiff. Its a fair compromise though.
Old Apr 1, 2004 | 06:28 AM
fireant's Avatar
Default Re: (Boilermaker1)
The 02 and 03 suspensions are the same fitment.
I also have FLT-A2's... no complaints, and I autocross them quite a bit... I keep them at about 11 out of 15 hardness and my daily drive is comfortable enough.
Some coilovers, like the KWs, are specifically designed to resist rust... which is an issue in some parts of the country.
Old Apr 1, 2004 | 06:41 AM
Todd00's Avatar
I said I don't want a title!
The Tein Flex is far from a track only suspension, as are the JIC FLT-A2's. Both will work fine on the street.
Old Apr 1, 2004 | 08:36 AM
taikahn's Avatar
Mugen Suspension.
$1000 from KingMotorsports. No mods, no adjustments, cheap/easy install. Cant go wrong.
Old Apr 1, 2004 | 09:44 AM
jimmyjames's Avatar
Have you checked out the D2s? They look comparable to the JIC and Teins, but are much less expensive. http://www.ephatch.com/forum/s...33069
Old Apr 1, 2004 | 12:17 PM
dpw41285's Avatar
Default Re: (jimmyjames)
anyone have the factory lowering struts and springs
Old Apr 2, 2004 | 07:10 AM
MrGrimm's Avatar
Default Re: (dpw41285)
get tein ss, rear camber kit with the progress rear sway bar, j's racing front and rear strut bar and j's racing c-pillar bar. that is going to be my setup.
Old Apr 2, 2004 | 09:18 AM
Default Re: (02CivicSi)
i was just reading about the D2's....
anyone know if they have a site? or any specs on them? or used them?
they look good, and rust is an issue here where i live.
Old Apr 2, 2004 | 02:07 PM
K20_Rey's Avatar
GROUND CONTROLS AND TOKICO SHOCKS!!!
I went with eibach sporlines with sotck shocks. Good enough for me. :D
Old Apr 2, 2004 | 05:17 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (K20_Rey)
Just wondering, I thought i read something about EP3 front suspensions where it is really hard to lower the car much at all without running out of travel REAL quick, so the only good option is to get something with a shortened shock.... whereas in the EG/DC/EK/etc, you can get away with a stock length shock and a decent amount of lowering. true?
Old Apr 3, 2004 | 06:30 AM
Default Re: (SkyeC)
i haven't read anything like that on the ep sites, i'll look around.
i read there is an issue with the tie rod? when lowering too much, and also there is a wierd creaking noise lowering too much, but thats the extent of the issues i've read.
uses0ap
May 9, 2008 01:42 AM
Topdawgg
Mar 8, 2008 07:19 PM
bgmat58
Dec 19, 2004 02:10 PM
blkeg
46
Jan 4, 2004 07:35 PM
vain
May 19, 2003 05:04 PM
