help diagnosing my problem. engine wont start !!
Old Mar 31, 2004 | 06:44 PM
Code Blue's Avatar
Default help diagnosing my problem. engine wont start !!
fresh rebuild, 0 miles, never been ran.
happened yesterday too. thought it was the battery so i got a new one from wally world. even did it today with the new battery so i threw it on the charger until it was completely charged, and the clicking still continues. i made a short little video describing the problem in action...
right click save as.
http://www.we-todd-did-racing....DE%3D
so far my buddy has said to check the grounds, and maybe the take the starter off and see if its spinning and also see if the crank turns without binding.
Old Mar 31, 2004 | 06:51 PM
SleepyHF's Avatar
Default Re: help diagnosing my problem. engine wont start !! (Code Blue)
clicking = starter
SleepyHF's Avatar
Default Re: help diagnosing my problem. engine wont start !! (SleepyHF)
got spark? got fuel? got combustion? then STARTER
Old Mar 31, 2004 | 07:05 PM
Code Blue's Avatar
i know i have fuel
other two i will have to check out
Old Apr 1, 2004 | 01:13 PM
Code Blue's Avatar
up
Old Apr 1, 2004 | 02:27 PM
Code Blue's Avatar
up again
Old Apr 1, 2004 | 03:09 PM
kreush33's Avatar
sounds like a bad starter to me, get a hammer and hit the housing while someone tries to start it, if you cant reach the houseing place a crowbar down to the housing and tap the end of the crow bar with the hammer, be patient it might take a couple times for it to start,
Old Apr 1, 2004 | 05:40 PM
mmuller's Avatar
Mad Scientist
Default Re: help diagnosing my problem. engine wont start !! (kreush33)
yep, sounds like the starter, grounds or connections to starter/battery
Old Apr 3, 2004 | 06:59 PM
Code Blue's Avatar
Default Re: help diagnosing my problem. engine wont start !! (mmuller)
as it turns out, the problem was with the ground. the starter grounds itself off the tranny, and the tranny ground wasn't in an efficient spot, so i just moved it the the original spot and voila
Old Apr 3, 2004 | 07:24 PM
SleepyHF's Avatar
Glad to hear you solved the problem
SpeedSeeker21
Sep 29, 2013 12:17 PM
85DX
Jan 9, 2005 12:46 PM
5po0n_Dc2
Nov 24, 2004 03:47 PM
RCautoworks
Jan 17, 2003 10:19 PM
ls_vtec_b18a1
Nov 4, 2002 07:12 PM
