z6 vtec solenoind. which wire goes to ground and which to rpm switch??
Old Mar 31, 2004 | 03:40 PM
civicracer1993's Avatar
Default z6 vtec solenoind. which wire goes to ground and which to rpm switch??
i have a z6 im puttin in my crx. but i do not have the plug that goes to the oil pressure switch and the ground.. so all i see is 2 metal pins inside the plastic where the plug from the engine harness is supposed to go , my question is which pin is for oil P and which is for ground?? i will be running this off of an RPM switch so do i need to hook up the ground?
Old Mar 31, 2004 | 06:26 PM
Default Re: z6 vtec solenoind. which wire goes to ground and which to rpm switch?? (civicracer1993)
anyone/
Old Apr 1, 2004 | 01:54 PM
up
mikester1222
23
Aug 28, 2016 01:34 PM
641iowaguy641
Jun 19, 2013 01:53 PM
91 DA Revived
Oct 28, 2010 05:25 PM
JSPECSIR
Oct 7, 2008 06:56 PM
TehMan
21
Nov 27, 2005 12:10 PM
