gsr thinking about going turbo
Old Mar 31, 2004 | 03:26 PM
xplanetearth420x's Avatar
Default gsr thinking about going turbo
alright i have a 95 gsr its all stock beside aem cai intake and comptech header right now im trying to decide if i want to go all motor or turbo trying to put prices together,i know i cant just slap on a turbo with my stock internals so my question is what internals should i get if i choose to go turbo
thanks
Old Mar 31, 2004 | 06:24 PM
Vtexivic's Avatar
Default Re: gsr thinking about going turbo (xplanetearth420x)
I did a GReddy turbo on my GSR, with all stock internals, and running low 13's.
Old Mar 31, 2004 | 06:32 PM
FlaN.'s Avatar
you can run with stock internals, but you might want to lower the compression a bit. I know my limits with my RS, but you might want to search a bit and figure out what needs to be done with the GSR. the search button is your friend
Old Mar 31, 2004 | 06:38 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: (Hanisbb21)
Hmmm, good question!
Is this the first time this topic has been covered?!
I wouldn't know, I don't use the search function either.
Old Mar 31, 2004 | 07:01 PM
Default Re: (integra707)
there is always someone that a dick this time its integra707 but thats besides the point i searched i found out a lot but i wanted to get people input that already have it done to see what they recomend and what they think about it,ive been doing a lot of searches mostly what i have learned from that is make sure my compression isnt too high and to make it lower on a gsr,ive had friends tell me not to use itr internals if im gonna go turbo and not to over boost but other than not i dont know that much more about it
so im asking people that have turboed there gsr's to help me find out a good set up that would cost too much i can afford the turbo but i dont know about internals and stuff right now it would have to be one or the other
Old Mar 31, 2004 | 07:03 PM
es four's Avatar
Default Re: (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">there is always someone that a dick this time its integra707</TD></TR></TABLE>
Take as many as you need.
Old Mar 31, 2004 | 07:12 PM
Rory Breaker's Avatar
You absolutely can run on stock internals. Stock compression, stock internals, stock everything for sure.
What makes you think otherwise? I would run a search, see what people have done in the FI forum, and then post some more specific questions. What are your goals? What do you want to do with the car?
Old Mar 31, 2004 | 07:14 PM
boostngsr's Avatar
Default Re: gsr thinking about going turbo (newgsrdriver)
yeah stock internals are fine, maby if you want a new head gasket that will lower it, i would put the money to a good egt and make sure you know how to tune or let someone else tune for you, thats all you need is good tunning
Old Mar 31, 2004 | 07:20 PM
Default Re: gsr thinking about going turbo (boostngsr)
right now im just going mod by mod i dont have a lot of money to put into my car i probly put on a mod every 2 months right now i have intake and header.i dont know what i want to do right now i just want to hang with the sti's and evo a lil better a lot of ppl have them were i live
Old Mar 31, 2004 | 07:48 PM
patdemps's Avatar
Alright. Maybe im just reading this to well BUT.......
Does your sig say "want Skunk2 Cams, etc." Also, you say you have a comptech header and intake. Do you realize that those 2 parts you CANNOT use with a turbo setup. The header and intake go my friend....those parts need to be sold. Also, your stock GSR cams would be better for turbo, just keep them and save the hassle. Also, I suggest searching like crazy through forced induction, you will find a ton of imformation. Talk to the members that are famaliar with Turbo and the ones that will help. I know I got lucky and found a few on board that were just awesome, they helped me pave the way and helped me with every step (on their own time). If you find the right people, ask the right questions and have respect from other board members then it should be fairly easy to figure this all out for yourself.
However, if you don't search, if you don't really know what your doing....then its going to be a long tough road. First figure out what you are getting yourself into, before you start dreaming big. I searched and studied for a good 6 months before I went turbo (I made sure it was something I wanted to do and was ready for...down time of not having a car, spending tons on parts, knowing that things can go wrong, realizing what kind of power I was going to have, etc).
Now onto the positives. Its going to be a blast if you decide to go turbo. You'll learn a ton of **** and have a good time along the road. Boost is addictive.....
what are your goals?
Old Mar 31, 2004 | 08:29 PM
95integraLS's Avatar
hes right though...this topic has been covered many times.
Old Mar 31, 2004 | 08:56 PM
boostin GSR's Avatar
Default Re: (95integraLS)
it's all about your horspower goals and tuning. then more tuning, and did i say tuning? cause u need that.
horsepower &gt; 300whp = some internal work needed (in my view/experience)
want to see what happens when things go bad with a stock internal running high boost? ... of course you do.. thank me later
https://honda-tech.com/zerothread?id=712410
eric
Old Mar 31, 2004 | 09:56 PM
Default Re: (boostin GSR)
well i was going to get cams and stuff but i realized i wanted to boost i know i dont need my header or intake more money to put towards to turbo, i have searched a lot maybe just not enough im just trying to get some feed back from ppl that are already boosting with gsr's i have heard a lot of different things ppl telling me to get internals and such im not thinking about getting the turbo till summer im doin my research right now,so basically ill be looking up stuff about boosten until then i really want to no the do's and donts
ive come to the dision i am using my stock internals but i dont know everything else to get new intake mani,fuel injectures?
Old Mar 31, 2004 | 11:42 PM
bryerz99ls's Avatar
you can your your stock internals u might want to invest in a new headgasket to lower your compression a lil
Old Mar 31, 2004 | 11:49 PM
Default Re: (bryerz99ls)
bump
Old Apr 1, 2004 | 01:02 AM
WhoisDan's Avatar
Most Integra owners go through this dilemma. I have over 10 friends that have Integra's and only one went Turbo. Reason is because you need a lot of money on the side if something goes wrong. My friends turbonetics turbo should be arriving to my house today as a matter of fact.
Old Apr 1, 2004 | 10:04 AM
Default Re: (whoisdan)
bump before school
Old Apr 1, 2004 | 10:11 AM
Audi A4's Avatar
why are u bumping this do a search like nick said..... theres so much info in the archives as well
Old Apr 1, 2004 | 12:06 PM
integrx's Avatar
New User
if your doing mod by mod every 2 months, just save your money, you won't be able to hang with sti or evo or srt-4 at the ned of a year. you're looking to spend $2000-4000 in mods, or get some nitrous!!!
Old Apr 1, 2004 | 12:28 PM
Default Re: gsr thinking about going turbo (integrx)
ill have 2000 in like a month,and no im not gonna run nitrous **** f*cks up your engine
Old Apr 1, 2004 | 01:17 PM
MikeTV
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">ill have 2000 in like a month,and no im not gonna run nitrous **** f*cks up your engine</TD></TR></TABLE>
No more than a turbo kit will. If you are on a budget, and you want to hang with the big boys, bottle feed your teggy.
Old Apr 1, 2004 | 03:00 PM
iNtoXicaTedSPOON's Avatar
Default Re: gsr thinking about going turbo (Eclipse spanker)
hahah SLAP on a turbo! i post this same post like about 2 weeks ago with the same word. cant juss SLAP on a turbo.
Old Apr 1, 2004 | 03:55 PM
Default Re: gsr thinking about going turbo (iNtoXicaTedSPOON)
who said anything about JUST SLAPPING on a turbo?
Honda_Si21
Apr 21, 2011 02:34 AM
whoopwhoop3
Apr 9, 2009 04:45 PM
lakaspeed
Dec 22, 2006 01:13 PM
94mugenintegra
May 22, 2002 03:17 PM
94mugenintegra
May 11, 2002 02:22 PM
