Turbo leaking oil?
Old Mar 30, 2004 | 02:51 PM
Firewerks's Avatar
Default Turbo leaking oil?
I installed a brand new t3 super 60 onto a B16 and found that after i started it i had a very minor oil leak comming from the turbine housing. unfortunatly i was using a 3/8s braided line for my return which isnt suffecient . my question is, if i just upgrade it to a larger line will it contiue to smoke? or is there some leeway before the turbo has to be re sealed?
thanks
Old Mar 31, 2004 | 08:06 AM
Firewerks's Avatar
Default Re: Turbo leaking oil? (illusionsir)
Bump
Old Mar 31, 2004 | 08:12 AM
ExVtec's Avatar
A brand new turbo shouldn't be smoking @ all. The seals should be fine. I would check all your oil connections...If thats not the case get a replacement...
Good luck....
Old Mar 31, 2004 | 08:59 AM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Turbo leaking oil? (ExVtec)
new turbo and seals shouldn't leak, check your oil fittings and connections good luck
boostedgsteg
Mar 1, 2006 09:34 AM
Blkteg97
Nov 16, 2004 08:04 AM
slo_crx
Oct 12, 2004 05:51 PM
