Greddy turbo timer and alarm, again....
i know this is old, but i see so many variables about how to go about wiring it, i have a 5 point harness, and i remember seeing one very good diagram before of how to wire it, but i cannot come across it anymore, if you can help i would appreciate it, dont tell me to search becuase i already have
Turbo timer and car alarm
(contributed by: allouthybrid via Xbird)
how to wire a greddy turbo timer with an alarm (again)
i completed this install last week and would like to help others who have pondered over this as well.
required tools/parts:
1. soldering iron
2. solder
3. wire stripper/crimper
4. five point relay (could be purchased at radio shack or other electronic stores)
5. butt connectors
6. wire tapper (taps into wire without splicing it)
7. 16 gauge wire
8. phillips and flathead screwdriver
optional accessories:
1. wire harness for five point relay
2. wire loom for that "so fresh and so clean" look
first off, i'll cover the basic wiring of the turbo timer. NOTE: this wiring is for a fifth gen civic and third gen integra. i'm not sure about other hondas or other vehicles.
-red on timer to solid white wire on ignition
-blue on timer to solid yellow wire on ignition
-green on timer to black/yellow wire on ignition
-black on timer to ground
optional:
-brown wire to wire(s) on e-brake. this safety feature cuts off the turbo timer if the e-brake is released for any reason during the countdown. if you have one wire this wire should more than likely work. if you have two wires, obtain a voltmeter and test each wire to see which wire gives off 0 volts when e- brake is engaged and 12 volts when the e-brake is disengaged. if that wire does what is described, that is the where the brown wire will be hooked up to.
ok, this second part covers the functioning of the alarm during countdown.
the operation of the alarm is possible through a five point relay. it is a relay with the points 30, 87a, 87, 86 and 85. "85 and 86 are the wires to the magnetic coil in the relay (used to activate it). therefore i wired 85 to the constant +12v (off my akarm wiring) (yellow wire on alpine alarm), and i wired 86 to the gray wire from the turbo timer. therefore while the turbo timer is counting down, the relay will be active.
"points 30 and 87a are normally closed on the relay. therefore, i cut the ignition wire for my alarm (red wire on an alpine alarm) and spliced points 30 and 87a in between." in other words, cut the ignition wire to the alarm, and connect point 30 to one side and 87a to the other side. don't connect the ignition wire back together with points 30 and 87a connected. i made this mistake at first and the relay didn't function correctly.
87 is open and not connected to anything at all.
during the count down, the ignition signal is interrupted and the alarm should be able to arm and keep the doors locked.
NOTE: for the alarm with the ignition safety feature, this feature will be disengaged during the countdown but will be re-engaged after the countdown. what i'm referring to is, usually if a key or other object is stuck in the ignition keyhole to start up the car when the alarm is armed, the alarm would go off. but with this install this feature is disengaged while during the countdown and will function normally after the countdown, as stated above.
I have another one that is a bit different than this one... but i know nothing about relay, i am not sure which one is right
__________________
http://www.geocities.com/thermalfid16/
I got this a while back hope it helps
I Still cant figure out how to do this. If you figure it out then let me know.
1. soldering iron
2. solder
5. butt connectors
7. 16 gauge wire
optional:
__________________
ok, this is getting kinda stupid, i have tried about 3 different ways to get this to work, and none have proved themselves, if anyone has ACTUALLY gotten this to work, i would appreciate your help.. i have gotten it to work to where, when you click back one time, the car stays running, but as soon as you turn the key all the wayback and pull it out it shuts off liek normal, i dunno, its getting frustrating...
one little prob....my del sol has one wire going to the ebrake. and it runs a neg 12v. yes NEGATIVE 12 v. i tested it with my meter. i put my positive probe on the battery positive and my neg probe on the ebrake wire. -12v. what the hell?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxAlan274xX »</TD></TR><TR><TD CLASS="quote">one little prob....my del sol has one wire going to the ebrake. and it runs a neg 12v. yes NEGATIVE 12 v. i tested it with my meter. i put my positive probe on the battery positive and my neg probe on the ebrake wire. -12v. what the hell?</TD></TR></TABLE>
yea, i couldn't get my ebrake one to work either, since there is only 1 wire you would thinkn it was a no brainer? my turbo timer wouldn't count down/turn off the car with the pbrake/RPM harness connected.
mike
mike
i wired mine all up by testing wires and then plugging up the harness. just figgure out the electrical configuration. the other directions are from thermal's site, but they dont work universally. good luck!
Lei Siew Long
Jun 30, 2001 12:17 AM
