really high idle
Old Mar 29, 2004 | 07:23 PM
pikappaphi's Avatar
Default really high idle
Hello everyone,
I need help. my civic is idling at 4 grand when its cold and then down too 2 grand when warm. what the hell could be causing this. the ecu isnt spitting anything out. I have a b16a in it.
Any ideas?
Old Mar 29, 2004 | 07:28 PM
DC 2's Avatar
Default Re: really high idle (pikappaphi)
You might have a vacuum leak, is it iradic?
Old Mar 29, 2004 | 07:39 PM
Starscream's Avatar
One of the problems of EFI its the adjust of idle speed, this because the ECU tends to compesate every manual adjustment we do, overiding them.
The solution is simple, you adjust the idle speed (with a warm engine) following the manufacturer instructions (usually a screw situated in the intake manifold, with the automatic air control unplugged), once you have the specified idle speed, you plug again the air control and unplug the battery for 5 minutes (this resets the ECU memory). Then you plug the battery again and start the engine, letting it idle for like 5 or 10 mintues, without touching the accelerator. This way, the ECU finds the optimum mix for the car and keeps it.
Hope it helps.
RockinthEFhatch
71
Jan 18, 2025 01:45 PM
3 Beepz
Mar 14, 2019 09:28 AM
enano
Oct 11, 2006 08:35 AM
dannylDAsport
Mar 28, 2004 11:38 PM
94SiSQO
May 3, 2002 02:46 AM
