blown head gasket?
Old Mar 29, 2004 | 06:18 PM
vtec_kman's Avatar
Default blown head gasket?
I think i might have a blown head gasket cause i been losing coolant water for weeks. I think the car was overheated. Everytime i would leave the car on the thermostat would read at high and goes up and down but when driving it is back to normal. At first i thought it was the tw sensor but it was not. At times i do have problems starting when the engine is hot or cold and it would crank. It would also flood sometimes. I need some suggestion to fix this real quick. This is a 94 honda accord with 165k miles on it.
Old Mar 29, 2004 | 06:20 PM
fw190bvi's Avatar
Default Re: blown head gasket? (vtec_kman)
is your exhaust gas abnormal in any way?
Old Mar 29, 2004 | 06:52 PM
vtec_kman's Avatar
Default Re: blown head gasket? (fw190bvi)
somewhat i think there is no white smoke but i see a little water dripping from the exhaust pipe though, is that somthing.
Old Mar 29, 2004 | 07:01 PM
iam7head's Avatar
I would highly recommend you to see if the fan work, i know it sounds silly but that's what happen most of the time.
honda's engine overheat ALOT faster than without the fan than most of the other cars i worked on.
check the coolant, see if there's any oily mily color.
Old Mar 29, 2004 | 07:12 PM
vtec_kman's Avatar
Default Re: blown head gasket? (iam7head)
yes the fan does work and yes there is an oily substance in the coolant.
Old Mar 29, 2004 | 08:21 PM
-RedneckDave-'s Avatar
Working
Sounds like a head gasket if the fan works and there is oil in the coolant. have fun with that it is really simple and should only take a few hours.
Old Mar 30, 2004 | 02:34 AM
shrekz's Avatar
get a head gasket tester from snap on it will tell you exactly what u have, do you have white smoke? at idle?
Old Mar 30, 2004 | 03:06 AM
vtec_kman's Avatar
Default Re: blown head gasket? (shrekz)
no white smoke at idle and how much do the head gasket cost?
Old Mar 30, 2004 | 10:16 AM
shrekz's Avatar
head gasket doesnt cost so much compared to the other gaskets you will need aka exhaust manifold gasket, intake manifold gasket, cam seal gasket. basically everything, but anyway the labor is an insane amount. but you should really get the head gasket test, it is way worth it.
Old Mar 30, 2004 | 11:05 AM
vtec_kman's Avatar
so ur saying that i need a head gasket tester for snap on but not the other things such as aka exhaust manifold gasket, intake manifold gasket, cam seal gasket.
mvtello1234
Jun 26, 2017 06:50 AM
hondafan89
Nov 13, 2013 01:16 PM
OItani
Aug 20, 2012 06:01 AM
Bobby808
Apr 27, 2005 11:22 AM
lostsol
Aug 19, 2002 08:38 PM
