Proper way to hook up a Dual Voice Coil sub?
Old Mar 28, 2004 | 10:53 PM
bradykiller's Avatar
Default Proper way to hook up a Dual Voice Coil sub?
as the topic reads.. never had one before.
Old Mar 28, 2004 | 11:03 PM
vigor5spd's Avatar
Default Re: Proper way to hook up a Dual Voice Coil sub? (bradykiller)
Depends how many subs you got? What are the ohm rating on the voice coils?
What kind of amp also?
Old Mar 29, 2004 | 09:51 AM
Default Re: Proper way to hook up a Dual Voice Coil sub? (vigor5spd)
it's a 800 watt speaker, and the voice coils are 4 ohm i believe.
the amp is a sony mx-2100gtx
-200 watts x 2 (4ohms)
-300 watts x 2 (2 ohms)
-600 watts (bridged @ 4 ohms)
Old Mar 29, 2004 | 12:35 PM
vigor5spd's Avatar
If you just have one speaker then wire it parallel to get a 2 ohm load. Most amps are 2 ohm stable.
Old Mar 29, 2004 | 05:56 PM
Eric R's Avatar
You can do that as long as the amp is stable at 2 Ohm when bridged. Read the manual.
Old Mar 29, 2004 | 09:03 PM
Default Re: Proper way to hook up a Dual Voice Coil sub? (Eric's R)
Cool, Thanks guys!
Old Mar 29, 2004 | 09:09 PM
dc24me's Avatar
In your setup, you want to run it in series. connect the (-) of the first vc to the (+) of the other, the connect the other terminals to the amp. This will give you an 8 ohm load mono, which is equivalent to 4 ohms stereo. Your amp is stable only to 4 ohms mono (bridged). If you connected them in series (+) to (+), (-) to (-), you'll have a 2 ohm load andn your amp will shut off.
Old Mar 30, 2004 | 02:36 PM
ndustryalGSR's Avatar
Default Re: Proper way to hook up a Dual Voice Coil sub? (dc24me)
http://www.jlaudio.com/tutorials/wiring/index.html
Old Mar 31, 2004 | 06:48 PM
eHoward's Avatar
We just got some Type Rs and I had to figure out how to wire a pair. Alpine has a ton of info on their site on how to do it.
ReV LiMiT
Audio / Security / Video
Mar 12, 2006 02:41 PM
deeweezy
Jun 23, 2004 02:36 PM
cd5_2NR
Apr 24, 2003 02:02 PM
Vp Special K
Sep 30, 2002 09:56 PM
USDM 4G VTEC
May 3, 2002 07:22 AM
