jl audio w6v2
Old Jun 23, 2004 | 01:44 PM
deeweezy's Avatar
Default jl audio w6v2
can a jl audio 12 w6v2 sub handle 1000 watts? if so wat 1000 watt mono amp do u guys think i should get i'm gettin 2 12 inch w6v2's?
Old Jun 23, 2004 | 02:04 PM
TnTWRX's Avatar
Default Re: jl audio w6v2 (deeweezy)
If you are getting (1) 1000 watt mono amp you will be pushing 500 watts to each. The optimal rms as per JL manual is around 400-500. I was only pushing 250 to each of my 12w6v2 and it was more than enough. Shook the shelfs on the wall at the shop.
As far as what amp it just depends on budget and voice coil configuration. I don't know if they come in dual 2 ohm, mine are dual 4 ohm. So look for an amp that can push out 1000w @ 4 ohm mono and wire them in a series/parallel config and viola...500w to each sub.
Here is a ohm end load calculator:
http://www.rockfordfosgate.com...d.asp
Here is (2) Dual 4 ohm series/parallel:
http://www.rockfordfosgate.com....y=11
Hope this helped
Old Jun 23, 2004 | 02:36 PM
luder22's Avatar
Default Re: jl audio w6v2 (TnTWRX)
You will be fine . I have 2 10" w6v2. Steve at JL audio said its a great match with my 1000/1 My friend had 2 12 w6v2's only problem is you need alot of current to keep your voltage high. Alot of times with my budd when really hard bass hit his 1000/1 would turn off because the voltage would dip below 11V I have one too just not installed yet. I have 3 ZX350's by PG i9f you are interested i was going to run 1 to each or 3 subs plans have changed though Good Luck
ReV LiMiT
Audio / Security / Video
Mar 12, 2006 02:41 PM
bradykiller
Mar 31, 2004 06:48 PM
mstewar
Sep 10, 2003 06:54 PM
cd5_2NR
Apr 24, 2003 02:02 PM
Vp Special K
Sep 30, 2002 09:56 PM
