DVC questions...
Old Apr 21, 2003 | 03:38 PM
cd5_2NR's Avatar
Default DVC questions...
i have an mtx 8302 amp..it runs around 400-425x1...and i want to hook up my 12' subs to it..right now they're wired series w/ a 4ohm load...will my amp hurt my subs..my subs are 300RMS and 1200 PEAK....my amp is also 4ohm stable...just wondering about the amps wattage vs the subs wattage...is it safe to push it with this amp..???
Old Apr 21, 2003 | 03:59 PM
t0p_sh0tta's Avatar
Default Re: DVC questions... (zeROTWO_CG6)
Does the amp do 400-425 at 4 ohms? Your subs and amp should be fine if you keep it wired at 4 ohms, but you might not get the most power there.
Old Apr 21, 2003 | 09:35 PM
cd5_2NR's Avatar
Default Re: DVC questions... (t0p_sh0tta)
yeah my amp runs stable at 4...would i get more out of them if i wired them down to 1ohm...oh btw, i tried them at 4...they hit hard as hell..
Old Apr 24, 2003 | 02:02 PM
Import13alla's Avatar
If your subs hit hard as hell at 4ohms, don't bother messing with it. Your amp runs cooler at 4 ohms. Also, I am not sure if your MTX is capable of handling a 1 ohm load, you might want to check up on that before wiring the subs differently. Also, I am pretty sure that if you wire them parallel instead of a series it will be a 2ohm load instead of 1, which I think your amp is stable at.
bradykiller
Audio / Security / Video
Mar 31, 2004 06:48 PM
Problemo
Dec 5, 2003 08:29 AM
Vp Special K
Sep 30, 2002 09:56 PM
USDM 4G VTEC
May 3, 2002 07:22 AM
woodog
Dec 17, 2001 11:08 PM
