New to turbo --> stupid wastegate spring question
Old Mar 28, 2004 | 11:56 AM
9deuce9rr's Avatar
Default New to turbo --> stupid wastegate spring question
With the spring rates. Is that rate the amount of boost i will be running at? Also, with the same spring, how far can you raise and drop boost from what it is rated at?
Old Mar 28, 2004 | 12:27 PM
Cezilla's Avatar
Default Re: New to turbo --> stupid wastegate spring question (WhiteLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude &raquo;</TD></TR><TR><TD CLASS="quote">With the spring rates. Is that rate the amount of boost i will be running at? Also, with the same spring, how far can you raise and drop boost from what it is rated at?</TD></TR></TABLE>
wastegates allows gas at a predetermined psi once reached to be released. its a way to somewhat regulate boost but not control it, thats where a boost controller comes into play.
Old Mar 28, 2004 | 12:32 PM
5STAR3's Avatar
yes... the spring rate is most always the psi it will run/release at.
yes you can go above your spring somewhat, usually double your spring rate is the max.
no you can not go lower than your spring rate.
Pumpking.
Nov 2, 2016 09:35 AM
ctownintegra
Jul 9, 2008 02:41 AM
radeon
Jul 9, 2007 03:22 AM
Short Round
Nov 12, 2003 10:16 PM
lucas569
Mar 20, 2002 11:32 AM
