Deltagate Wastegates, do they really suck?
Old Mar 27, 2004 | 08:39 PM
ITSTOCK's Avatar
Default Deltagate Wastegates, do they really suck?
Well ive seen some posts in the past where some people say that the delta gate wastegates suck, but ive also seen that its also where its positioned that can make it suck. Well i might switch over from internal to external wastegate but im pretty broke as it is and can pick up a deltagate for half the price of a tial etc. Anyway, id liek to get some feedback whether good or bad about the deltagate WG from people who have actually owned one, thanks.
Old Mar 27, 2004 | 09:13 PM
yimmy's Avatar
Default Re: Deltagate Wastegates, do they really suck? (ITSTOCK)
Most of the people that say they suck heard it from someone else. I never had any problems with mine but I was only running 10psi. If your running lower boost you shouldnt have a problem. There is guys making 500hp with deltagates.
Old Mar 27, 2004 | 09:17 PM
ITSTOCK's Avatar
Default Re: Deltagate Wastegates, do they really suck? (yimmy)
I plan on running 14-15 psi, i figure it would probably hold up better then an internal either way.i just dont want any boost spikes/creep.
Old Mar 27, 2004 | 09:23 PM
2muchPSI's Avatar
my deltagate did suck, couldnt hold 7 psi, switched to a Tial, and never creeped again
Old Mar 27, 2004 | 09:32 PM
ITSTOCK's Avatar
Default Re: Deltagate Wastegates, do they really suck? (2muchPSI)
How bad did it creep?
Old Mar 27, 2004 | 09:45 PM
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote"> There is guys making 500hp with deltagates.</TD></TR></TABLE>
That made me think of something....I believe the deltagate is rated for 400 crank hp
Old Mar 28, 2004 | 12:54 AM
Trac226's Avatar
Default Re: Deltagate Wastegates, do they really suck? (D-Man)
Well it sucked on my set up...spiked to 13 lbs. Low compression on #3 so I'm in the middle of a short block swap at the moment.
Old Mar 28, 2004 | 01:02 AM
safe driver's Avatar
Default Re: Deltagate Wastegates, do they really suck? (Trac226)
the design of the manifold may have contributed to the boost creep.. [hint]drag manifolds[/hint]
Old Mar 28, 2004 | 06:07 AM
ITSTOCK's Avatar
Default Re: Deltagate Wastegates, do they really suck? (safe driver)
Exactly, my hf manifold spiked like a mother ****** on my d series setup.
Old Mar 28, 2004 | 08:25 AM
This One's Avatar
ive have never had any problems with them.
I did have some creep problems recently on the deltagate and was told to switch to tial which i did and it still creeps, so in thta case its not the WG
Old Mar 28, 2004 | 08:56 AM
ITSTOCK's Avatar
Default Re: Deltagate Wastegates, do they really suck? (tHIS oNE)
Are you using the drag mani?
Old Mar 28, 2004 | 09:05 AM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">Are you using the drag mani?</TD></TR></TABLE>
hell no
Old Mar 29, 2004 | 08:35 AM
2muchPSI's Avatar
Not at low psi, and if it was the manifold, replacing the wastegate wouldn't have helped any. It holds rock solid with the Tial
GSROWNSU
Apr 12, 2007 11:33 AM
gsr x civic
Apr 7, 2007 09:57 AM
KURUPTinc
Jul 12, 2005 01:04 PM
W O T
Jan 23, 2005 09:08 PM
60-1
Jan 31, 2004 05:41 PM
