problem with thermostat
Old Mar 27, 2004 | 06:38 PM
rob_honda's Avatar
Default problem with thermostat
i just had my water pump fix and new timing belt changed and thermostat. WHenever i drive around and the engine is hot the thermostat would rise up to the top and goes up and down. SInce then my car would crank and sometimes would be flooded with gas. My friend said i might have a bad tw sensor. This is a 94 honda accord with 167k miles on it. Any help would be appreciated.
Old Mar 28, 2004 | 05:03 AM
legacytunes's Avatar
Default Re: problem with thermostat (rob_honda)
? do your fan's come on? does it do it with the ac on or off? u might have a defective thermostat like your thinking. the best thing to do would get a new one and see if it still does it. its the cheapest way out. then i would presurerize the cooling system to see if you have leaks . if all is good. you had a lot of air in the cooling system and therefor you have an air pocket causeing the problem. good luck i hope you get it st8.
Old Mar 28, 2004 | 09:09 AM
rob_honda's Avatar
Default Re: problem with thermostat (legacytunes)
yes my fans come on and i just recently change my thermostat but the problems is still there.
Old Mar 28, 2004 | 03:26 PM
ef9wpb's Avatar
i have the same problem.. i changed the thermostat and did the water pump a while ago ....so im thinkin its the fan relay or fan switch in the block... the fan wont come on unless you turn on the a/c as well... and then it will bring the temp down and shut off... if u figure it out before i do.. please pm me
thanks.
Old Mar 28, 2004 | 04:37 PM
rob_honda's Avatar
Default Re: problem with thermostat (ef9wpb)
does ur car sometimes crank and be flooded when the engine is hot.
Old Mar 29, 2004 | 12:51 AM
shrekz's Avatar
did you bleed the cooling system?
Old Mar 29, 2004 | 03:45 AM
rob_honda's Avatar
Default Re: problem with thermostat (shrekz)
what do you mean by bleed the cooling system
Old Mar 29, 2004 | 06:51 PM
ef9wpb's Avatar
never had a problem with it being flooded... but yeah mine is bled.... on or around the t-stat housing there's a lil bleeder valve... u keep that cracked while u fill your coolant and fill it till coolant starts to bubble out... but check a manual for better instructions
Old Mar 29, 2004 | 09:25 PM
solo2slocivic's Avatar
have you changed the TW sensor yet???? they are not that expensive
Old Mar 30, 2004 | 03:13 AM
rob_honda's Avatar
Default Re: problem with thermostat (solo2slocivic)
yes i have changed the thermostat but still there is the same problems, might be a blown head gasket i think?
Old Mar 31, 2004 | 07:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob_honda &raquo;</TD></TR><TR><TD CLASS="quote">yes i have changed the thermostat but still there is the same problems, might be a blown head gasket i think?</TD></TR></TABLE>
i asked if you had replaced the TW SENSOR not the thermostat....
TW/thermal sensor they are 34 bucks, mounts in the bottom of the radiator, tells the pcm what temp. the engine coolant is. when they go out of spec your pcm could think the engine coolant is 30 deg F instead of 200 deg F thus causing extreme problems at start up and driveability problems....
Old Mar 31, 2004 | 08:09 PM
spankey167's Avatar
Just had my timing belt, water pump, etc... and i think the only thing that you might not have replaced is #14 on the pic... its labled as Sensor (A-93) It is like a fan sensor switch that tells the fan for the radiator when to come on... I heard they go bad after a while... so just had my changed at the same time.
Old Apr 1, 2004 | 04:04 AM
rob_honda's Avatar
lol i did had my tw sensor replaced but the problem still exist
Old Apr 1, 2004 | 04:05 AM
rob_honda's Avatar
Default Re: problem with thermostat (spankey167)
naw i dont think its the fan switch because the fan turns when the engine is hot.
kodylive
May 1, 2013 05:46 AM
tech410
15
Sep 22, 2010 05:22 AM
moosta936
Jul 9, 2007 05:59 PM
dc5mikeydc5
Apr 12, 2005 08:06 AM
jhwells
Apr 9, 2003 02:52 AM
