boost gauge
Someone please tell me what's the easiest route from inside the car to the engine bay because I need to run a vacuum line to the boost gauge, be specific, and thanks
There's a hole behind the dashboard at the passenger side. A rubber piece needs to be taken out. Drill a hole and put the wires(vacuum line) in the middle.
The hole is about 30 to 40 cm above the ECU.
There is also a smaller hole that is 20 cm above the hole i just mentioned.
goodluck
goodluck
