built NA sohc w/ safc question-
Old Mar 25, 2004 | 04:12 PM
builthatch's Avatar
MiG-21 superfan
Default built NA sohc w/ safc question-
on the apexi site, it says that 12-14%+ will sometimes induce a check engine lite, due to the map sensor voltage being so low (as if it sees boost, the afc manipulates the map sensor signal and fools it inot thinking more air is going thru than what is really going thru, so in turn, more fueling occurs)...well, my car, sometimes, will throw a lite it seems from it being set at 11%+.... I think it mite be from that fact that my car sees a little bit of positve manifold pressure at full throttle; the afc will show .01-.02..where as most NA hondas it seems at full throttle show .00..my theory is, my high compression, big cam, porting, etc make the map sensor voltage that much lower at full throttle than most hondas due to the increased air being pulled in, so the lite being thrown @ 11% makes sense.
Do you agree?
also, after having this safc since 1999, i noticed for the first time that in the accessory position, car not running, that the pressure was @ 0.00 (usually its at like -007,8), so, i tried another MAP sensor jsut to verify and it read the same...i am suspecting that this mite very well be why i threw the code @ 11% today...i think the atmoshperic pressure today, in combo with my motor setup, is the culprit...
Old Mar 26, 2004 | 11:12 AM
builthatch's Avatar
MiG-21 superfan
Default Re: built NA sohc w/ safc question- (builthatch)
no one has an opinion about this?
TravisCadello
18
Oct 17, 2008 07:40 AM
lovey408
Jun 18, 2007 04:34 PM
backwoodsman
Mar 26, 2007 07:03 AM
builthatch
Mar 26, 2004 09:25 PM
thashadow
Jun 12, 2002 11:35 AM
