Squeek When turning Steering wheel
Old Mar 25, 2004 | 03:07 PM
pbizzlegsr's Avatar
Default Squeek When turning Steering wheel
when my engine is off and at a complete stop i tried turning the wheel..and as i turn the wheel i hear squeeking..does that have something to do with the power steering belt? all belt were checked and up to spec..? any help
Old Mar 25, 2004 | 03:09 PM
dannylDAsport's Avatar
Default Re: Squeek When turning Steering wheel (pbizzlegsr)
probaly need to flush ur power steering fluid, check what color is it. it suppose to be clear.
Old Mar 25, 2004 | 03:19 PM
JoshRambo's Avatar
Default Re: Squeek When turning Steering wheel (dannylDAsport)
where is the sound comming from?
when I had my R It was squeeking where the steering column went through the firewall. if that is the case you need to lube up that area. I had the dealer do it for me.
Old Mar 25, 2004 | 03:40 PM
pbizzlegsr's Avatar
Default Re: Squeek When turning Steering wheel (Gravity)
it sounds like its squeeking around the left wheel area where the spring is at..
Old Mar 28, 2004 | 06:58 PM
IVI's Avatar
IVI
if the engine is off it has nothing to do with power steering, or any pumps or belts. check the boots and bushings and ball joints. squeaking is an early sign of something not good. always make sure you fix suspension problems right away.
Ventolin
May 14, 2008 11:45 AM
rayzian
Mar 12, 2008 03:06 PM
Dongoesby
Dec 26, 2005 02:07 PM
x00gsr
Dec 16, 2002 02:55 PM
yellowbuffalo
May 17, 2002 10:28 PM
