Lowering ? (steering)
Old May 16, 2002 | 02:53 PM
yellowbuffalo's Avatar
Default Lowering ? (steering)
All i have on my car for now is the eibach pro kit. Well now when i find it weird because when i wanna move the wheel i have to turn my wheel more than nessecary can anyone relate and what I should.
[Modified by slipknot23, 2:39 AM 5/17/2002]
Old May 16, 2002 | 05:05 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Lowering ? (slipknot23)
no idea, i noticed no change in my steering, and i'm dropped nearly 2" on H&R Sport.
Old May 16, 2002 | 10:03 PM
vteg's Avatar
New User
I did not notice anything different also. Did you get an alignment?
Old May 16, 2002 | 11:10 PM
Calavera's Avatar
Default Re: Lowering ? (vteg)
Not quite sure what your problem might be. So you have to turn the steering wheel alot more than you used to before you lowered it?
I have pro-kits and have had no problems at all.
Old May 17, 2002 | 01:12 AM
intekragsr's Avatar
Default Re: Lowering ? (Calavera)
should have no effect on the steering
Old May 17, 2002 | 05:45 AM
neo1z's Avatar
Default Re: Lowering ? (intekragsr)
is it harder to steer? maybe you accidentally removed your power steering belt or something
Old May 17, 2002 | 06:42 AM
Neo's Avatar
Neo
Bingo! Check your power steering and get an alignment.
Old May 17, 2002 | 08:14 AM
Fooser's Avatar
Default Re: Lowering ? (Neo)
Do you have wider rims or something else your not mentioning?
Check your power steering belt and fluid.
Old May 17, 2002 | 09:39 PM
Default Re: Lowering ? (Fooser)
i haver the stock rrims and got an alignment also and was done all done at Acura
Old May 17, 2002 | 10:28 PM
boipika's Avatar
yeah i lowered it with sprint, 2 inches, with tokiko illumina, steering did get a little bit more stiff.
ajmitch51
May 5, 2014 05:58 AM
Ventolin
May 14, 2008 11:45 AM
TurboBumblBee
Apr 13, 2003 05:57 AM
garados
Jan 5, 2003 07:08 PM
animated_life
Oct 10, 2002 03:22 PM
