coilover spring rate question
Old Mar 28, 2004 | 04:27 PM
JHD_DA's Avatar
Default coilover spring rate question
i have some coilovers with a spring rate of 575 front and 475 rear and its a bit bouncy. how would it ride and handle if i put the 475 in front and 575 in back? i know the stiffer spring rate in back helps on launches tho.
Old Mar 28, 2004 | 05:37 PM
Smeeg Heed's Avatar
Default Re: coilover spring rate question (JHD_DA)
not well. the front wouldn't bounce as much but the back would go all over the place. on a bumpy road you might even lose control of the car. 575 is a very high spring rate for the relatively light rear end of an integra. Why did you get them so high in the first place? My skunk2s are 450/350 (I think) and I thought that was high.
EDIT: also remembered that this would make your front end a lot lower and back end a lot higher than it already is.
Old Mar 28, 2004 | 07:10 PM
b18oldbodyhatch's Avatar
Anytime you put on coilovers your going to have a bouncy ride because the spring is much smaller than the stock on.
Old Mar 28, 2004 | 07:13 PM
zomart's Avatar
Default Re: coilover spring rate question (b18oldbodyhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18oldbodyhatch &raquo;</TD></TR><TR><TD CLASS="quote">Anytime you put on coilovers your going to have a bouncy ride because the spring is much smaller than the stock on.</TD></TR></TABLE>
umm... bouncy or rough? the ride should be less bouncy, but rougher. you should feel bumps more, but your car shouldn't bounce. if it's bouncing, that's your shocks, not your springs.
jdmturbo1127
Suspension & Brakes
Sep 26, 2007 08:42 AM
Blizzard
Suspension & Brakes
Jul 7, 2006 06:25 PM
ITR0065
Apr 7, 2006 02:31 PM
krys83
Suspension & Brakes
46
Mar 23, 2005 06:02 PM
combustion
Oct 23, 2003 05:50 AM
