Another question about B18C1 swaps
I just bought the engine, and I'm in the process of getting everything together for the install.
What else do I need for the install?
So far, I need:
upper rad hose
cv joint
rear mount
throttle cable
Am I missing anything? Besides of course the obvious engine and tranny. :D
So far, I need:
upper rad hose
cv joint
rear mount
throttle cable
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRG Performance »</TD></TR><TR><TD CLASS="quote">I got your answer right here
Impressive use of your 5 posts a day.....
What kind of car is it going into?
EDIT: pwned all those guys
you're a ****** retard. if you don't have anything useful to contribute, stfu.
to the other guy, what kind of car do you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRG Performance »</TD></TR><TR><TD CLASS="quote">Sorry guys but my nos fogger was leaking and im a little dizzy ya know.
so your head is in the engine bay?
in regards to this question, the car type and year are kinda important factors in this question.
Shift linkage
Mounts
some wire, some soder
a helms manual
Oil
Tranny fluid
New plugs
Shift linkage
Mounts
a helms manual
Oil
Tranny fluid
New plugs
is the motor OBD2 or OBD1? that will make a difference if the motor is OBD1, in that case you will need a conversion harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexualbanana »</TD></TR><TR><TD CLASS="quote">With the exception of the rear mount, what about the other mounts? Do I use the old ones from my original engine?</TD></TR></TABLE>
you will be using an Si drivers side mount and rear mount i believe. do a search in the hybrid forum.
you need to read
... and now I'm dun with you.
you need to read
You will find all of your answers here http://www.phear7imports.net/s...6gen/
UnspokenTruth
May 10, 2004 05:32 AM
