vtec pressure valve (code 22) coming up?
Old Mar 25, 2004 | 10:39 AM
Racerage1's Avatar
Default vtec pressure valve (code 22) coming up?
my friend has a D16Z6 and his CEL(code 22) would come on only in 3rd gear, full throttle, and above 5k RPM. it also gives us a code 43 (fuel supply). could anyone help us fix this? what can i check to clear these codes? thanks
Old Mar 25, 2004 | 10:47 AM
Katman's Avatar
Default Re: vtec pressure valve (code 22) coming up? (Racerage1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerage1 &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a D16Z6 and his CEL(code 22) would come on only in 3rd gear, full throttle, and above 5k RPM. it also gives us a code 43 (fuel supply). could anyone help us fix this? what can i check to clear these codes? thanks</TD></TR></TABLE>
have you guys done any kind of modifications to the engine? add anything new, etc ?
Old Mar 25, 2004 | 10:59 AM
Racerage1's Avatar
Default Re: vtec pressure valve (Katman)
not recently. but it had a headgasket job done and the head is a JG one. thats all he said.
Old Mar 25, 2004 | 11:01 AM
Katman's Avatar
Default Re: vtec pressure valve (Racerage1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerage1 &raquo;</TD></TR><TR><TD CLASS="quote">not recently. but it had a headgasket job done and the head is a JG one. thats all he said.</TD></TR></TABLE>
ooook.
and how far after the h/g job did the VTPS code start happening?
Old Mar 25, 2004 | 11:06 AM
Racerage1's Avatar
about a month
Old Mar 25, 2004 | 11:53 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerage1 &raquo;</TD></TR><TR><TD CLASS="quote">about a month </TD></TR></TABLE>
have you looked over the connections? make sure all grounds are grounded, etc ?
try unplugging the ecu and leaving it out for about 1 minute, then re-plug it back in and try starting the car?
Old Mar 25, 2004 | 01:36 PM
tinkerbell's Avatar
could be oil pressue to!!!
Vt3c_eg
Jun 11, 2008 04:37 AM
Quickridez_3
Dec 16, 2006 05:02 PM
otakueric
14
Feb 11, 2004 10:45 AM
hybridEj6
Feb 10, 2004 11:34 AM
1ntensiveVTECivic
Nov 17, 2003 07:32 AM
