ANOTHER IDLE SURGE PROBLEM...AHAHHAHAHAHHAHHAHA
Old Mar 25, 2004 | 10:16 AM
LoSt is BlaCk's Avatar
Default ANOTHER IDLE SURGE PROBLEM...AHAHHAHAHAHHAHHAHA
i have been trying to figure this thing out for too long...and it seems like it could be anything at this point. so now i must turn to my fellow h-t members. i have searched however it seems like everybody has a slightly different situation on there hands!
here's the problem:
when the car makes it's first cold start of the morning the idle is super high (around 3,500 maybe even higher). during the warm up the idle is smooth, lol. once the motor gets warm the fun begins as the car drops down to about 1,000 rpm then starts surging up to about 1,500 rpm. i have also noticed a loss in pressure in the brakes as i sit at stop lights. i checked the brake booster by removing the hose and plugging it and my idle problem did not change...i then proceeded to remove my charge pipe as it was running and plugged the top hole in the throttle body and my idle problem went away! i also tried plugging the bottom one and the car proceeded to shut off. at this point i thought it was the idle control valve on the back of the intake mani...so i changed it...i then started the car again and my idle problem was still there! FAWK!!!!
let me know if you need more info...
any and all help would be awsome peeps, thank in advance!
Old Mar 25, 2004 | 12:04 PM
MissLady's Avatar
Default Re: ANOTHER IDLE SURGE PROBLEM...AHAHHAHAHAHHAHHAHA (Chpt1onBOOST [DMV])
Old Mar 25, 2004 | 02:04 PM
gsrcivic619's Avatar
i have the SAME EXACT problem, idles high when cold, then drops down. what could it be?
Old Mar 25, 2004 | 02:06 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chpt1onBOOST [DMV &raquo;</TD></TR><TR><TD CLASS="quote">]i have been trying to figure this thing out for too long...and it seems like it could be anything at this point. so now i must turn to my fellow h-t members. i have searched however it seems like everybody has a slightly different situation on there hands!
here's the problem:
any and all help would be awsome peeps, thank in advance!</TD></TR></TABLE>
sounds like a vacuum leak. check ALL YOUR HOSES!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote">i have the SAME EXACT problem, idles high when cold, then drops down. what could it be?</TD></TR></TABLE>
its NORMAL for the car to idle high (1500ish) when you first start it, then when the car warms up it drops back down. its so the engine gets up to operating temprature quicker.
Old Mar 25, 2004 | 09:37 PM
Default Re: ANOTHER IDLE SURGE PROBLEM...AHAHHAHAHAHHAHHAHA (Kamin)
i have checked them a few times, even fixed a few of them...still got no result...
oh yeah the car throws no codes either!
Old Mar 25, 2004 | 10:37 PM
Hawkze_2.3's Avatar
Try replacing ALL of your intake manifold gaskets...Over time they can get soaked in oil from the PCV valve and deteriorate....Worked for me
Old Mar 26, 2004 | 05:07 AM
EE_Chris's Avatar
What engine are you dealing with?
At the end of the day, your engine should be able to idle on its own without the use of a IACV (or FITV is so equipped). The idle air bypass screw (on the throttle body) should be set to allow enough air into the manifold to get the engine to idle at ~500rpm.
So on a warm engine, unplug the IACV; What does the idle do? If you have a FITV, and its leaking air (as it shouldn't be on a hot engine), plug the bottom hole in the throttle body. What happens to the idle now?
After the IACV is unplugged, and FITV hole plugged as well, your idle should be ~500rpm. If its above this, there are a few possible causes: throttle plate stop screw messed with, thus affecting TPS output; air in the coolant system; vacuum leaks.
b20eg9daddy
Oct 25, 2008 12:37 PM
bb4 jdm lude
Mar 12, 2008 09:25 AM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
chirp2hrd
Oct 13, 2002 01:36 AM
