an-r intake manifold gasket causing smoking!!!??
Old Mar 25, 2004 | 08:22 AM
esoterEK..'s Avatar
Default an-r intake manifold gasket causing smoke!!!??
me and my brother bought two an-r manifold gaskets a couple weeks ago and after putting it on..the motor smokes like crazy out of the exhaust (both our cars)...is it the gasket? or??
it seems like the gasket is too thick..and causing the injectors to push out too far..
once the gasket is in..i can only screw in like 3 threads from the manifold to the head..
maybe thats the problem??
does anyone have a similar problem with the an-r gaskets??
help me out guys..
my car is smoking like craaaazy!! black smoke with a strong *** smell..
Modified by EGkwazhimoto at 9:58 AM 3/25/2004
Old Mar 25, 2004 | 08:24 AM
rodrez.'s Avatar
Default Re: an-r intake manifold gasket causing smoke!!!?? (EGkwazhimoto)
If you can't get enough of the threads to meet, you might need to pull the studs, and use new/longer ones.
Old Mar 25, 2004 | 08:50 AM
esoterEK..'s Avatar
Default Re: an-r intake manifold gasket causing smoke!!!?? (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">If you can't get enough of the threads to meet, you might need to pull the studs, and use new/longer ones. </TD></TR></TABLE>
but is that the problem??..i dont wanna waste money on something that's not the problem..
anymore helpP..??
Old Mar 25, 2004 | 08:58 AM
esoterEK..'s Avatar
bump help..
Old Mar 25, 2004 | 09:24 AM
toolowsol's Avatar
You did completely remove the old gasket right? Down to bare shiny metal?
Old Mar 25, 2004 | 09:27 AM
tilt's Avatar
i have the anr gasket on my gsr. it works fine. My guess would be you may be leaking coolant where the manifold meets the gasket and is being sucked into the engine combustion chamber.
also you are using bolts instead of studs and nuts. might want to make sure the bolt end isnt hitting the bottom of the thread hole. ah i just noticed you said you are using 3 threads. not good. make sure you bolt the whole thing down snug.
Old Mar 25, 2004 | 10:39 AM
esoterEK..'s Avatar
Default Re: an-r intake manifold gasket causing smoke!!!?? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">i have the anr gasket on my gsr. it works fine. My guess would be you may be leaking coolant where the manifold meets the gasket and is being sucked into the engine combustion chamber.
also you are using bolts instead of studs and nuts. might want to make sure the bolt end isnt hitting the bottom of the thread hole. ah i just noticed you said you are using 3 threads. not good. make sure you bolt the whole thing down snug.</TD></TR></TABLE>
thanks for the info..ill check
Old Mar 25, 2004 | 06:14 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkwazhimoto &raquo;</TD></TR><TR><TD CLASS="quote">
anymore helpP..??</TD></TR></TABLE>
Waste of money? If you're only making contact with 3 threads, thats not good at all. New studs would run about $5.
Anon51
Jun 14, 2010 06:58 PM
AllmotorGSReg
Nov 19, 2009 12:12 PM
turbotime
Dec 13, 2005 01:08 PM
Shizznaz
Sep 2, 2005 08:07 AM
MR. MIYAGI
Mar 26, 2004 08:01 PM
