axle nut with a torque wrench?
Old Mar 25, 2004 | 06:13 AM
citrusdrop's Avatar
Default axle nut with a torque wrench?
O.k. who has broken loose an axle nut w/o air tools? I have been trying for an hour. I've only done it with air tools before, it was taken off less then 7000 miles ago. Torque wrench is not cutting it WTF
Old Mar 25, 2004 | 06:16 AM
toolowsol's Avatar
Default Re: axle nut with a torque wrench? (citrusdrop)
dude, are you trying to break your torque wrench?!!?! Use a big *** breaker bar, with a pole over the end, keep the wheels on, and the car on the ground.
Old Mar 25, 2004 | 06:22 AM
tilt's Avatar
uhm yeah, use a breaker bar with cheater bar if you must.
Old Mar 25, 2004 | 06:38 AM
Maintenance's Avatar
Default Re: axle nut with a torque wrench? (tilt)
It shouldnt be too hard. Just get a 2 ft breaker bar. That usually get a standard civic or integra axle nut out with ease, on preludes its a little harder. If that doesnt do the job then bust out a 5 foot breaker bar. If you cant break it with a 5 ft bar then you need to hit the gym.
Old Mar 25, 2004 | 06:48 AM
blackeg's Avatar
Default Re: axle nut with a torque wrench? (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Use a big *** breaker bar, with a pole over the end, keep the wheels on, and the car on the ground.</TD></TR></TABLE>
. and dont be afraid to throw a 5 foot pole over the end of the breaker bar, that **** works like butter. also try using some pb blaster if the nut is all rusted and nasty looking
Old Mar 25, 2004 | 07:02 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
seriously, NEVER loosen a nut or bolt w/ a torque wrench, it will either break it or screw it up, making it inaccurate for tightening nuts or bolts in the future.
Breaker bar and cheater pipe is where it's at.
Old Mar 25, 2004 | 10:27 AM
doublejz's Avatar
Default Re: axle nut with a torque wrench? (PatrickGSR94)
1" rachet with a 5ft pipe, bounce on the pipe it'll break loose
Old Mar 25, 2004 | 10:30 AM
JDMlyfestyle's Avatar
breaker bar has always gotten off the axle nut. dont use your torch wrench. if u did use it i would go somewhere and have it checked out to make sure its still accurate other wise u have to get it recalibrated
Old Mar 25, 2004 | 10:41 AM
asmallsol's Avatar
basicly what everyone else said.
Put the wheel back on and pop the center cap out. This way you should be able to fit the 32mm socket on the nut. Have someone Hold the brakes, plus you have the friction of the tire on the ground, so the wheel shouldn't move.
Now use trq =Fxr on your side. If your applying 100lbs of force to a ft long breaker bar, then your only applying 100ftlbs. Now if you apply 100 lbs to a 10 ft cheater bar, your now applying 1,000ftlbs.
Physics Own.
Old Mar 25, 2004 | 10:59 AM
Happyman's Avatar
Default Re: (asmallsol)
Ahhh, you all are ******. No need for a breaker bar. I used a standard 3/8th drive ratchet with a 19mm closed wrench on the end. Broke her right loose. You sure you going to the left? Lefty loosey righty tighty!
Old Mar 25, 2004 | 11:25 AM
Grimm's Avatar
Default Re: (Happyman)
just stomp on the handle...
Old Mar 25, 2004 | 11:27 AM
JSPECHB's Avatar
Its cold a pry bar between the wheels studs and break that sonna bitch loose!
Old Jul 19, 2004 | 11:51 AM
RSVTECDC4's Avatar
Default Re: (JSPECHB)
dang..i just broke that **** off. i drilled a hole and i chiseled away
Old Jul 19, 2004 | 12:54 PM
asmallsol's Avatar
Default Re: (RSVTECDC4)
way to bring up a 4 month old topic to say you broke a nut loose
Old Jul 19, 2004 | 12:58 PM
FWejCOUPE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">way to bring up a 4 month old topic to say you broke a nut loose </TD></TR></TABLE>
i'm pretty sure he got it off by now.
i got a 3 ft break bar from harbor frieght and i get it of like its nothing
Old Jul 19, 2004 | 01:02 PM
SolObsession's Avatar
Default Re: (JDMlyfestyle)
I can't believe no one has mentioned to make sure to unstake the axle nut.
Old Jul 19, 2004 | 02:13 PM
pdiggitydogg's Avatar
I use a 1/2" breaker bar and a 2.5' steel pipe extension.....comes off like nothin
Old Jul 19, 2004 | 02:35 PM
SimpleGreen's Avatar
okay the axle nut has a pinch in the bolt.. so un-pinch then try it! haha
Dj Porboi
45
Aug 4, 2010 04:39 PM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
AViciousTHRUST
Nov 12, 2006 11:45 PM
Quetzolcotl
May 9, 2006 06:04 PM
echo999
May 24, 2002 06:22 AM
