d16z6 block with y8 head........what headstuds?
Old Mar 24, 2004 | 03:34 PM
Infinite Auto's Avatar
Default d16z6 block with y8 head........what headstuds?
ok so i have a 95 z6 block, with a 96 y8 head.......the rest is unimportant for now, but i have searched many places to find the correct info on what headstuds to use.....i found one source that said it was the y8 headstuds, so i ordered arp y8 headstuds......i got them brand new yesterday and screwed them in, and when i slide the head over them only a few are long enough to even start putting on a nut and washer, but 6 of them arent long enough to even come all the way through the hole.......so am i doing something wrong or do i need different headstuds? sorry if i sound like a jackass and thanks for the help!
Old Mar 24, 2004 | 04:37 PM
D-Man's Avatar
Default Re: d16z6 block with y8 head........what headstuds? (B18TurboEF)
what is the arp part # of the ones you bought?
Old Mar 24, 2004 | 04:48 PM
Default Re: d16z6 block with y8 head........what headstuds? (D-Man)
208-4305 is the part number
Old Mar 24, 2004 | 04:54 PM
D-Man's Avatar
one end of the stud has more thread on it than the other,you try flipping them around?
Old Mar 24, 2004 | 04:56 PM
D-Man's Avatar
btw..I used 208-4301s for my D16Z block + Y8 combo,I had to use extra washers on two studs cause they were too long,the rest were fine.
Old Mar 24, 2004 | 05:01 PM
ya i tried both ways, but i talked to some people and they said i should use z6 headstuds and not the y8 ones i have.......ill get some overnighted and it should be all good! thanks for the help dman
Old Mar 24, 2004 | 05:10 PM
D-Man's Avatar
you might need two studs from that Y8 kit so you dont have to run washers on the new Z6 ones..The one with the Z gets 2 extra washer,the X gets 1 extra if you use all Z6 studs
intake side
Z O O X
O O O O
exhaust side
Try two of those Y8 studs in Z and X and see if this fit ok
93turbo16
Mar 19, 2012 11:38 AM
Maxpower350
Feb 25, 2006 11:57 AM
Jdm_Ek_Hatch
12
Sep 23, 2005 05:14 AM
Turbo-Ekhatch
Jul 6, 2005 12:06 AM
pip9
Jul 17, 2004 02:01 PM
