GSR Swap ? with CEL
Old Mar 24, 2004 | 03:14 PM
mrbsponge's Avatar
Default GSR Swap ? with CEL
I have a 00 GSR swap (obdII) with a OBDI ECU and a fields vtec controller. The car runs fine.... First, i have no o2 sensor YET. But the weird thing is its throwing Code 6 which I believe is a coolant temp sensor code. But why is that the only code its throwing when I dont even have an o2 sensor hooked up? All I can think of is a pin might be crossed somewhere in the harness? Any other ideas? Thanks.
Old Mar 24, 2004 | 03:52 PM
dunkd's Avatar
get o2 sensor in and see if it still does it.
Old Mar 24, 2004 | 03:54 PM
mattssi's Avatar
Default Re: (dunkd)
I had the same issue the other day with my car only throwing a code 21 when i had mothing hooked to the vtec solinoid, when i hooked up the solinoid, then i started throwinh a code for the pressure switch, but not till after i hooked up the solinoid? weird obd1 stuff?
mrbsponge's Avatar
Default Re: (dunkd)
Thats the obvious answer lol. Thats already a plan, i need a new one.
civicboy1128
13
Nov 7, 2013 11:50 AM
DarkBB4
Aug 27, 2005 09:31 AM
MysteryWagon
Mar 10, 2005 08:07 PM
00WhiteEKy
Aug 24, 2002 04:13 PM
6SPD_EK
Feb 20, 2002 02:52 PM
