To straight pipe or not to straight pipe
Old Oct 22, 2001 | 03:50 PM
I-VTECRX's Avatar
Default To straight pipe or not to straight pipe
well i have a built b16 in a 90 integra w/ ctr intake cam/itr valve springs (dual)/ itr manifold/ ctr piston .25 over/ knife edge crank/ 12lb flywheel/ S1 cable tranny/ fields vtec controller/should i straight pipe on a stock exahaust and headers? im gonna do a dyno soon!!! can someone enlighten me thanks
Old Oct 22, 2001 | 05:25 PM
Dr Pooface's Avatar
Default Re: To straight pipe or not to straight pipe (EF8hYbRid)
Buy a high flow cat and be nice to the environment.
Old Oct 22, 2001 | 06:06 PM
AllMotorMark's Avatar
straight pipe it for the dyno,
sweet bud I have a 92 teg ready for a b18c5 swap, motor being built up a bit first.
G2's for life!!!
Old Oct 22, 2001 | 07:29 PM
rainforest's Avatar
Default Re: To straight pipe or not to straight pipe (T.O.STREETRACER)
smash the **** out of you stock cat and not get a ticket.
Old Oct 23, 2001 | 01:45 AM
B18C-EJ1
Guest
Posts: n/a
Straight pipes are nice for top end power, but as for low end torque, they do nothing. Plus they make the exhaust loud as F*k, and it stinks good.
If you're at the track, I highly recommend it, but otherwise, get yourself a good highflow cat, and call it a day.
Side note - I have a built GSR engine in my EJ1, pushing about 190WHP NA, and about 270WHP NOS'd, I'm using a Random tech 3" universal cat. Works perfectly, flows nicely, and I've had no problems in the last 18 months I've owned it.
Old Oct 23, 2001 | 02:25 AM
Gasoline Fumes's Avatar
Default Re: To straight pipe or not to straight pipe (rainforest)
Bad idea. Unless you put a pipe inside the cat, you will hurt flow.
Old Oct 23, 2001 | 08:48 AM
Spade's Avatar
Dude, get a highflow from magnaflow. The fine is $3000 in Cali
Old Oct 23, 2001 | 02:49 PM
owen_the_soyboy's Avatar
Default Re: To straight pipe or not to straight pipe (Spade)
actually that is a FEDERAL FINE.... so you can get a $3000 ticket in ANY state.. OUCH!!!!!
OH_1fstgsr
12
Sep 5, 2010 02:22 PM
azandford
Apr 30, 2010 08:20 AM
KRWTEK1
Feb 5, 2007 07:42 PM
mugenspoongsr
Aug 22, 2005 02:04 AM
BlackCRX
Sep 12, 2002 10:33 PM
