Having Problems with Exedy Clutch Engaging....HELP!
Old Mar 24, 2004 | 01:49 PM
cinq's Avatar
Default Having Problems with Exedy Clutch Engaging....HELP!
Just wanted to see anyone has the problems I'm having. I just installed the Exedy cerametallic thick on my gsr swap...and having a hard time getting it into gears...can't get in any gear...just 2nd gear barely. I bled the clutch..new fluid...that didn't work. I took out the the clutch and reinstall it again..thinking I did something wrong the first time. Same thing...clutch won't engage at all. Anyone else having this problem or know how to fix it? Thanks.
Old Mar 24, 2004 | 02:38 PM
iiilgsrlll's Avatar
Default Re: Having Problems with Exedy Clutch Engaging....HELP! (cinq)
Bump...i'd like to know too..contemplating buying this clutch.
Old Mar 25, 2004 | 05:38 AM
cinq's Avatar
Default Re: Having Problems with Exedy Clutch Engaging....HELP! (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">Bump...i'd like to know too..contemplating buying this clutch.</TD></TR></TABLE>
Old Mar 25, 2004 | 10:19 AM
Dan GSR's Avatar
possibly installtion error
maybe installed the disc in backwards?
Old Mar 25, 2004 | 11:30 AM
doublejz's Avatar
Default Re: Having Problems with Exedy Clutch Engaging....HELP! (Dan GSR)
if the clutch is in backwards, you shouldnt be able to get it into any gear while running, but when its off you should be able to cycle through them
Old Mar 26, 2004 | 06:33 AM
cinq's Avatar
Default Re: Having Problems with Exedy Clutch Engaging....HELP! (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">if the clutch is in backwards, you shouldnt be able to get it into any gear while running, but when its off you should be able to cycle through them</TD></TR></TABLE>
I double checked...it's not in backward...plus... I don't think you can put in backward without the clutch touching the flywheel bolts...the fat side of the clutch facing the pressure plate....
Old Mar 26, 2004 | 11:30 AM
tgreaves's Avatar
Did you get your flywheel stepped to the correct numbers..
harmonator84
Transmission & Drivetrain
Aug 28, 2008 10:14 AM
civicsi18
Aug 16, 2008 08:11 AM
4LugR
May 9, 2005 10:07 AM
onyx00
Mar 19, 2004 09:10 PM
TuRbEeZy
Apr 4, 2003 10:14 AM
