Anyone using a Ultra MDI?
Old Mar 24, 2004 | 01:17 AM
Andre's Avatar
Default Anyone using a Ultra MDI?
I would like to know how the ignition is triggered and programmed. Does it have a knock retard and boost retard? Does it need any additional sensors?
And my last question: Where to buy?
Old Mar 24, 2004 | 01:00 PM
Andre's Avatar
Default Re: Anyone using a Ultra MDI? (Andre)
No one?
Old Mar 25, 2004 | 01:02 AM
visi0n's Avatar
the distributorless kit? umm its pretty much JDM bling. the stock ignition system is proven to work on powerful cars. even Ericks Racing's record breaking civic uses a stock ignition system.
Old Mar 25, 2004 | 03:52 AM
Andre's Avatar
Default Re: (visi0n)
Yes, the distributorless kit.
This is the only "info" i have found about it yet:
But the feedback sounds promising. It is plug&play and uses the OEM harness and sensors.
I don't like the other systems that comes with their own harness and sensors. Also kits like the HPX doesn't retain power steering
Old Mar 25, 2004 | 12:15 PM
sgT's Avatar
sgT
Default Re: (Andre)
there is no programming.
Its just a conversion to 2 coil vs 1 coil.
I will be doing testing on this soon
Old Mar 25, 2004 | 12:29 PM
00MRSi's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">there is no programming.
I will be doing testing on this soon</TD></TR></TABLE>
Is something like this even worth it? The stock ignition seems more than adequate..
Old Mar 25, 2004 | 12:31 PM
Andre's Avatar
Default Re: (sgT)
How is the ignition triggered? From the ECU?
Old Mar 25, 2004 | 12:34 PM
sgT's Avatar
sgT
Default Re: (Andre)
from the distributor yes.
Old Mar 25, 2004 | 12:36 PM
Kicker773's Avatar
Default Re: (00MRSi)
if you do a search there is a detailed explanation on why this isn't worth it unless your just into it for the bling..
Old Mar 25, 2004 | 12:42 PM
Andre's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">from the distributor yes.
Sorry, but i don't understand this. You mean that it retains the stock sensors from the distributor and with this sensors the ECU tells the M.D.I. when to fire?
Old Mar 25, 2004 | 01:08 PM
sgT's Avatar
sgT
Default Re: (Andre)
yes
Old Mar 25, 2004 | 05:36 PM
Kengs's Avatar
Default Re: (Kicker773)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">if you do a search there is a detailed explanation on why this isn't worth it unless your just into it for the bling.. </TD></TR></TABLE>
And how many of those people have actually seen (let alone try) an Ultra 9680 MDI???
Old Mar 25, 2004 | 06:33 PM
Kicker773's Avatar
Default Re: (kengs)
three people
Old Mar 26, 2004 | 04:33 AM
Andre's Avatar
Where can i buy a new or used MDI? Anyone want to sell?
Old Mar 28, 2004 | 08:12 AM
Andre's Avatar
Default Re: (Andre)
Last try, $500 for a used Ultra MDI in good condition or $700 for a new one. Who wants to sell?
SB97civic
10
May 17, 2004 07:49 PM
Screamer
Apr 6, 2003 08:30 AM
GSRacer1
Nov 8, 2002 10:05 PM
austrian type-R
Jan 17, 2002 01:08 PM
