OIL leak, wtf?
Old Mar 23, 2004 | 05:28 PM
T25So's Avatar
Default OIL leak, wtf?
I took my car to get an oil change the other day...anyways, I have an oil leak...jack it up, there is oil all over the underside of the pan...no apparent cracks, I think I might change the oil....what should I torque the oil drain bolt to (96 sol). Also, id be going from mobil one 5w-30 to penzoil synthetic 10w-30....is this ok, even without replacing the oil filter? The filter was replaced prolly 1k miles ago.
THANKS GUYS!
Old Mar 23, 2004 | 05:33 PM
ej1 pilot's Avatar
Default Re: OIL leak, wtf? (T25So)
take your oil pan off and put a new gasket on, make sure to criss cross the bolts, and you may need to take your header off
Old Mar 23, 2004 | 05:36 PM
T25So's Avatar
Im just gonna try to torque the oil dran bolt....what should it be torqued to? I dont have any torque wrenches, so how could I do it by hand?
Old Mar 23, 2004 | 05:39 PM
ej1 pilot's Avatar
Default Re: (T25So)
uh i work at a lube shop and we just tighten it by hand than give it 2 or 3 good tugs with a wrench, make sure you replace the drain plug gasket, thatll help too
Old Mar 23, 2004 | 05:41 PM
T25So's Avatar
hmmmm, well, theres just some yellow stuff around the drain plug and a washer....help?
Old Mar 23, 2004 | 05:50 PM
iwhichisme's Avatar
jsut curious, why are you going to 10W-30 synthetic, are you boosted? Also i would do as mentioned earlier, and check the oil pan gasket. also just to be one the safe side i would check the oil filter, to make sure its tightly secured.
Old Mar 23, 2004 | 05:58 PM
ej1 pilot's Avatar
Default Re: OIL leak, wtf? (iwhichisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">jsut curious, why are you going to 10W-30 synthetic, are you boosted? Also i would do as mentioned earlier, and check the oil pan gasket. also just to be one the safe side i would check the oil filter, to make sure its tightly secured.</TD></TR></TABLE>
yeah you shouldnt do 10W-30
and i doubt its the oil filter, cause even a small filter leak will spwe oil everywhere very noticably when you turn the car on
ANewHondaOwner
Honda Civic (2016 - Current)
Mar 23, 2019 06:09 PM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
tilhasbb
17
Aug 13, 2007 08:17 AM
pinoyboy204
Oct 7, 2005 03:15 PM
JDM-EJ1
Oct 2, 2004 02:32 PM
