Oil Sending Unit...
Old Mar 23, 2004 | 03:36 PM
Yellwtyper's Avatar
Default Oil Sending Unit...
I'm in the process of adding my turbo onto my 2000 lude. I just need to know where in the world is my Oil sending unit for the oil feed line?
Old Mar 23, 2004 | 03:38 PM
SuperSlow's Avatar
Default Re: Oil Sending Unit... (Yellwtyper)
Oil sending unit sits between your filter and the block.
Old Mar 23, 2004 | 07:12 PM
homesauce's Avatar
Default Re: Oil Sending Unit... (SuperSlow)
It should be somewhere directly below ur oil filter, if it's anything like a 4th gen, which im sure it is.
Old Mar 23, 2004 | 08:27 PM
aznpreludeSH's Avatar
Default Re: Oil Sending Unit... (homesauce)
i herd its a pain in the **** to get to for the oil feed line. pls, lets have some info on this
Old Mar 23, 2004 | 11:00 PM
homesauce's Avatar
Default Re: Oil Sending Unit... (aznpreludeSH)
it's as much of a pain in the *** as changing ur oil filter...
Old Mar 24, 2004 | 01:05 AM
@ries's Avatar
If it's a base model then it is directly below the oil filter. It has a rubber Hershey Kiss top with a wire. If you have an SH model... good luck getting to the sending unit.
Old Mar 24, 2004 | 07:24 AM
prelittlelude's Avatar
hope you have a bspt to npt adapter, if you don't. then when you try and screw in a T fitting your going to **** your threads all up
kmaz93da
Jun 30, 2010 01:12 AM
JohnnieChimpo
Jan 7, 2009 10:40 PM
turbotime
Oct 20, 2006 12:03 PM
Xerxes
Aug 28, 2004 02:02 PM
