GSR Rev Limit = ?
Old Oct 22, 2001 | 10:10 AM
jabroni95gsr's Avatar
Default GSR Rev Limit = ?
Just to clarify, because i want to get a set of itr/ctr cams and want to make sure I am taking advantage fully of their perf without having to change the internals (like springs etc) and ecu. Correct me if I'm wrong, but you could essentially just swap these bad boys in and then rev every time to like 8300rpm. If i were to stop at 8 or 8100, i would be cutting myself short. However, i want to get the real place where the rev limiter kicks in.
Does this strategy even make sense?
pls help. Thanks.
Old Oct 22, 2001 | 10:26 AM
sackdz's Avatar
Default Re: GSR Rev Limit = ? (jabroni95gsr)
Your redline is whereever you want it to be, but the cams are not the limiting factor. To rev higher, stiffer valve springs and titanium retainers would be a good start.
Old Oct 22, 2001 | 12:07 PM
BoM's Avatar
BoM
Default Re: GSR Rev Limit = ? (sackdz)
fuel cut is 8200
shift 8400
or get another tach, stock tach is off a couple 100+/-
Mr. DeOro
Aug 16, 2009 04:55 PM
Petah
Jun 18, 2003 04:08 AM
HondaLife
14
Mar 8, 2003 12:33 PM
Toretto
Jan 26, 2002 07:18 AM
