Built d16z6 in 95 dx coupe - almost done, i just need your help
Hey guys, almost done with the drag car, but i have a couple questions.
when adding vtec - what do i do
I am using a d15b7 wiring harness
i know add the wire to A4, but is that it?? i have an empty plug on the back of the vtec selenoid - i think. whats that for?? pressure switch?? now where does that one go and is the knock sensor the sensor up under the dizzy??
anything else you all can think of that i may be forgetting???
i have a helms at home im gonna check later, but im at school and thinking of it, so why not.....
THANKS!!!!!
THANKS!!!!!
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
vtec pressure is a 2 pin conector on the vtec selenoid if you are using the proper plug the blue wire with a black stripe will be the wire you will need to extend to the computer which will need to go D6. The other wire which will be a solid black needs to be grounded a good sorce ie. thermostat housing. to my knowledge you will not be using a knock sensot on a single cam, but here it is anyways knock- pin locationD3.... good luck
THANKS HOOKUPS!!!!!
much appreciated.
this is the first vtec wring hassles i have ever had to do.
my last car was a b18b turbo, so i had no wiring stuff to do.
Thanks again!!!!
much appreciated.
Thanks again!!!!
