wiring up vtec
First youll need this.
http://www.phearable.net/tech/...5.jpg
You will need two comman honda Connectors.
2 pin connector to ground pressure switch.
And another for VTEC solenoid.
Im not sure if OBDI B16's have a knock sensor, If so youll need to wire that in also.
They say you need a sheiled wire for the knock sensor but others say it grounds itself on the block, Ive never used a sheilded wire and have been fine.
It seems like a PITA but it seriously only takes about 30 minutes.
Resident Gearhead
Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode »</TD></TR><TR><TD CLASS="quote">
Im not sure if OBDI B16's have a knock sensor, If so youll need to wire that in also. </TD></TR></TABLE>
Yup, they do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode »</TD></TR><TR><TD CLASS="quote">They say you need a sheiled wire for the knock sensor but others say it grounds itself on the block, Ive never used a sheilded wire and have been fine. </TD></TR></TABLE>
Same here.
Yup, they do.
Same here.
